Blue smoke in high rpms
Hey guyz. to start with its a poormans type r. I just finished rebuilding the whole motor. From top to bottom. acl bearrings to honda rings (yes they r clocked right) to a resurface, valve job and seals on a 2000 b16 head. the bottom is a 2000 gsr c1 block. I have arp head studs. now car drives perfect just smoke in higher rpms.
I smoke a lot when i frist put it together and rebuilt it to realize there was a never a pcv valve in the back . i went to autozone and bought a ls pcv valve.
Its not smoking like before but now only smokes in high rpms.
Compression came up 215 215 215 215 in each cylinder. I dont know what it could be.. the head gasket was torqued down on the motor twice before i actually turned on the car tho. i used copper spray also.
Any help would be great
i used just normal advanced oil for the first 200 miles then changed oil then i used advance oil again till 500 miles. ive read so many things only and people say if u actually push it a lil, its a lil better for the break it. www.breakinsecrets.com. Ive only pused it about twice but its just the higher the roms the more it burns.
apparently your losing compression at high rpms, can either be the rings still haven't seated, or there is ring flutter do too a bad cylinder honing or cheap rings. gap could also be too loose.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
just keep driving it normalll.......Same thing happened to me one time and it just took more miles to file the rings into place...
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
