1988 Civic Dx D16z6 Turbo Build....Comin back
Old May 26, 2011 | 10:03 AM
b15spec's Avatar
aint no reg. spec-v
Default 1988 Civic Dx D16z6 Turbo Build....Comin back
Alrighty guys, I have been out for a while, and thought a couple months ago i miss it
A few months ago i picked up a 88 ef hatchback shell for the year and original body it was pretty clean for the price, had rear and front lip mudflaps etc.
I started about 2 months ago, and i plan on finishing by my birthday (june 30th) mainly everything under the hood the was not there is going to be brand new no short cuts taken. i picked up a z6 block disassembled then straight to the machine shop for prep, honing etc.
Motor set up
Obd1 d16z6
micropolished crank
LS eagle rods
Arp rod bolts
Vitara Turbo pistons 75mm stock bore 25-30psi
clevite bearing
STOCK head
skunk2 IM
full head job 3-angle etc.
arp head studs
arp head bolts
Transmission-
Si-cable tranny
stg.2 clutch exed.
fidanza 7lb flywheel
Turbo kit-
Cast iron log manifold
t3/t4 hybrid 63 AR turbo
3in downpipe
dsm 450's
38mm wastegate
Hondata map sensor
2.5in piping
greddy type-s bov
mishimoto intercooler
Just a few of what i plan on doing within the month, Still need to assemble motor and do the misc. stuff under the hood such as radiator, starter, etc...here a few pics, dont have much yet but will update as the build goes on.
power goals? Hopefully on dyno day i put down around 300whp, with the stock head i will probably max out aroudn 18-20 psi, later plan on building the head as i go for more towards 400whp. Yes its a single jingle and its gonnnaaa ride
Negative comments to yourself / to each their own. I will update as i go, thanks for looking
When i first got her home, i have the side molding and all to put on just havent touched much
Went a little crazy on the VC's
Turbo pistons, paineted the piping, Turbo
https://www.tamparacing.com/forums/signaturepics/sigpic51275_1.gif
Old May 26, 2011 | 10:33 AM
b15spec's Avatar
aint no reg. spec-v
Just got the block back bottom end should be put together this week
Old May 29, 2011 | 04:17 AM
Paulino's Avatar
Not harsh, just truthful
Where's the wiring harness and ecu breezy?
Old May 29, 2011 | 10:08 AM
b15spec's Avatar
aint no reg. spec-v
I Still need to pick an obd0 up with a jumper harness. Im going to have to get an ecu sent to me with a basemap when im done
Old Jun 8, 2011 | 05:37 PM
Lavertue24's Avatar
Looking real good man. Should be a beast!
Old Jul 10, 2011 | 07:16 PM
dohcvtec's Avatar
You boys like Mexico!!!
Hell Yeah Man GL I Just Sent Mine Off For Paint Today Im Doing A Built Y8 On 15 Pounds Looking For The Same Numbers..I got My Roll Cage Coming Soon And My Blue Rims I Just Need A Good Pair Of Slicks..Keep Us Updated And I Wanna Know Ur Numbers After You Tune
Springhill
22" Nothing less
Old Jul 27, 2011 | 12:43 PM
Paulino's Avatar
Updatesssss
Thiago_0_0
For Sale/WTB Honda & Acura
11
Feb 28, 2010 02:30 PM
2ooocivicsi
May 26, 2009 05:43 PM
DDOGGTPA813
Dec 24, 2008 01:09 PM
WagonMaster
May 5, 2007 05:05 AM
