Type r Turbo build
Old Mar 5, 2011 | 04:37 PM
vlad82's Avatar
vlad
Default Type r Turbo build
Yo what's up Almost done with this little project that took 2yrs just wanted to know how much horse power can i get on this motor with out changing any parts yet and how high on the boost can i safely run on the stock motor
Old Mar 7, 2011 | 09:35 PM
Importracer13's Avatar
99CivicSi
not to be a dick bro but GOOGLE is ur best friend and so it H-T... but boosting a stock itr..... NO BUENO!!!!!!!!!!!!! compression is to high... dont get me wrong it can be done but not recomended especially stock......
I <3 BOOST
EM1 Crew Member #16
OVERDOSE CUSTOMS FROM BASIC MAINTENCE TO ENGINE SWAPS, CAR AUDIO , PAINT AND BODY
Honda,Toyota, Nissan,Ford,Chevy Dodge, Everything
14525 62nd streeet north Unit 3&4
Clearwater FL 33760
CALL OR TXT 727 465 8295
Iggy Azeala
Old Mar 8, 2011 | 11:31 AM
vlad82's Avatar
vlad
Thanks man
Old Mar 8, 2011 | 11:33 AM
vlad82's Avatar
vlad
So should i sell the itr and get a Gsr or somthing
Old Mar 8, 2011 | 01:07 PM
The Fast Acura's Avatar
Has teh VTEK!
what are you trying to do? turbo setup? id run the itr with full bolt ons and a good tune, you should be able to get a good amount of power out of it all motor. but if your looking to turbo the best setup would probably be a ls/vtec turbo, or you could just buy new pistons for the type r motor
K*Squad
DC-Crew #37
STRICKLY MT
Old Mar 10, 2011 | 04:52 PM
vlad82's Avatar
vlad
yea that sounds like a plan buying new hardware
Old Mar 12, 2011 | 10:08 PM
Has teh VTEK!
so your planning on running a type r motor?
K*Squad
DC-Crew #37
STRICKLY MT
Old Mar 14, 2011 | 10:40 AM
vlad82's Avatar
vlad
Yea Im running the type r I've tryed trading on here but nothing so I boosted it
Old Mar 17, 2011 | 05:25 PM
01LatinVizionGSR's Avatar
I don't know why people comment on topics they no nothing about type R compression is 11.1.1 which is not that high. The red EK that is in my sig is a type r Boosted it made 307whp at 10psi's with a very very conservative tune and it has been running for 2 years and it doesn't even burn a drop of oil. I have boosted many motors with type R compression and never had an issue as long as you get a good tune you will be fine. With the higher compression less boost is needed to gain HP but the higher compression increases temp inside the combustion chamber which can cause ringland failure but if you do the math anything under 12 psi's and under will not increase the EGT enough to cause any significant difference. BOOST the TYPE R!!!!!!!!!!!!!!!!!!!!
Old Mar 17, 2011 | 05:31 PM
vlad82's Avatar
vlad
Thank bruh so all have to do is find a good tuner thanks again man
90ef
Projects and Builds
11
Jun 18, 2010 05:56 AM
JO TECH
Projects and Builds
10
Feb 5, 2010 02:38 PM
raskal589
For Sale/WTB Honda & Acura
67
Nov 20, 2009 06:27 AM
