poor mans type r build
Old Dec 29, 2009 | 03:54 PM
90ef's Avatar
Default poor mans type r build
whats yo... well im building a poor mans type r... but what crank should b best for me to use a GSR or LS... i was thinking to use the LS whit GSR rods and LS pistons... is that good or just use everthing from a GSR or what should b better
Old Dec 29, 2009 | 08:57 PM
88_Hatchy's Avatar
I'm cooler than you
There is only one way to build a "poor man's type r". GSR block/crank/rods, type r pistons (b16 pistons would work also), B16 head w/ type r cams. Oh yeah, you can't use the crank/piston/rod combo you selected.
Old Dec 30, 2009 | 12:42 PM
USDM4g4d's Avatar
formerly D00MSB08
You cant use LS crank w/ GSR rods.
& ls pistons wouldn't be a great choice.
R.i.p My Big Brother Pablo Garcia III 9.28.85 - 9.05.07
The Man, The Myth,
The Legend.
Power Of DREAMS.
Originally Posted by K20A2
Nothing wrong with a B series
Old Dec 30, 2009 | 12:48 PM
custom240sx's Avatar
DC Crew Member #1
GSR block, LS crank/rods/p73 pistons, b16 head, ITR cams and springs. This will net you a stroked GSR with basically and ITR head.
Old Dec 30, 2009 | 08:17 PM
EK20Si's Avatar
runs shit
Iva always wondered what a poor mans type r was
Originally Posted by Ink
Welcome to TR, whats the address this car is stored at?
Old Dec 30, 2009 | 10:10 PM
FoxHondaRider's Avatar
Registered Hater
Dont forget the B16 transmission.
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Dec 30, 2009 | 10:32 PM
2TONECB7's Avatar
Y0uNG PiFF
So if i throw itr cams an springs in my b16 head thats = to a type r head????
USDM [H] PiMP
TR "Old Skool EF" Member #175
FT + UP TO 1000 ON TOP.. WAT U GOT??
TR police interceptor Member #01
Old Jun 17, 2010 | 06:49 PM
Gotrice?'s Avatar
basicly. i think a type r head is ported a lil bit differently though also.not sure though
Midori Teg in the making..
Old Jun 17, 2010 | 06:58 PM
YARO's Avatar
Smith & Wesson Protected.
You gotta match the rods and the crank. So if gsr/type R crank gsr/TypeR rods. LS crank ls rods. If you don't have any of the parts yet go with the ls 89mm crack gives you more displacement. If you already have a GSR engine stick with it and throw valve/springs/retainers/cams and bolt on's. If this is gonna be a n/a application go with something like b16/type R piston for higher compression.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Jun 17, 2010 | 07:16 PM
FreshmanJoe's Avatar
I'm building a B18b1 right now probably going to use the Integra Type R P73 pistons rather than the Civic Type R p30's for higher comp. The PCT however raise Comp. to high 12's or low 13's. To high for my set up. Use this website it helps A LOT!!!!!! zealautowerks.com
TR "Old Skool EF" Member #124
EF-1991 Civic EX Hatchback W/Built D16 - SOLD!!!
EJ1-1993 Civic EX Coupe W/ B18 - SOLD!!!
EK-1998 Civic EX Coupe W/ Stock D16 -DD!!!
