cleaning your chain
Old Jul 24, 2007 | 05:02 PM
squid00's Avatar
teh clit wiggler
Default cleaning your chain
does anyone use brake parts cleaner to clean their chains? i used it one time and damn..... it took off all the nasty grease asap.
is it safe to use for chains?
Old Jul 24, 2007 | 05:51 PM
Boostin97SE-R's Avatar
Resident Asshole
i wouldn't use the chlorinated brake cleaner as that will swell o-rings. Non chlorinated is probably fine but I am not 100% on that. Suzuki recommends kerosene
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
Old Jul 24, 2007 | 05:54 PM
LS1ETR's Avatar
kerosene
and dont do it with the bike in gear and on stand.... i have like 3 friends that have almost lost their fingers.
Old Jul 24, 2007 | 07:10 PM
Ricksta's Avatar
I FUCK LIKE A PORNSTAR
i dont think you want your chain squeekey clean, i cant imagine your chain being full of globs of dirt. otherwise it needs to be lubed up regularly
sig pic removed
Originally Posted by pnkpnthr2133
that shit looks jagged, she's gotta open her mouth at some point so ricky can stick his dick in it...i don't want him to get hurt...
Old Jul 24, 2007 | 07:40 PM
a69tarbaby's Avatar
tsb bike ho
a clean chain helps prolong the life of the spockets and chain. regular brake clean works fine. don't forget to spray the front sprocket area. let the brake clean sit a few minutes and rinse with water. for heavier build up, spray again and use a brush.
right now, mine is the cleanest its ever been.. then again, it just got replaced along with new sprockets! i'm bad about keeping mine clean, but i'm going to try to keep this set cleaner.
Originally Posted by Brandon
you guys throw around that squid stereotype like a drunk bitch at a frat party
I'm not riding fast... just flying at a low altitude!
Old Jul 24, 2007 | 08:21 PM
RSXTC's Avatar
yep, ima member
i was looking at my chain today..its pretty nasty...i really need to get on it..
L-O-V-E L-I-F-E
Old Jul 24, 2007 | 09:05 PM
Signal7cbr!'s Avatar
hates change
X2!
Originally Posted by b16sleeper
don't worry...if i see a white guy with an afro...i'll yell crackhead and watch the cops tackle you before you touch me..
Old Jul 25, 2007 | 03:51 AM
jabtay's Avatar
Wheres the damn detonator
Mines filthy as well...too many rainy days
so do you just spray the kerosene on and let it sit then rinse?
"The only thing necessary for the triumph of evil is for good men to do nothing."
"Si vis pacem, para bellum"
Old Jul 25, 2007 | 04:03 AM
nunyo's Avatar
Now with less suck
I usually clean with WD40 and this; I finish up with a heavy coat of chain wax.
Old Jul 25, 2007 | 05:46 AM
TNathe's Avatar
if you guys are CLEANING your chains, take them off the bike. I always have cleaned my chains in a bucket of diesel fuel (because its cheap and readily available). Let them soak for a few minutes then use a parts cleaning brush and go over it. When done I use an air compressor to blow all the grit out and in the end i end up with a spotless chain. Put it on the bike go down the road briefly to heat the chain up, then apply ur fav lube
