Oops??
Old 02-07-2005, 03:02 PM
i like the blue ones
Hybrid_eg's Avatar
Default Oops??
I think I may have a short/bad connection somewhere...The car is a 90 civic Si, OBD1 conversion, SOHC VTEC swap, blah blah. It had NO problems at all before we took the motor out, now, the fuel pump doesn't cycle on and the brake lights are stuck on...Any ideas, suggestions, anything?
Shut yo ass up nugguh..
ReginaVagina
Old 02-07-2005, 05:17 PM
I'm Awesome
lead's Avatar
you are grounding out somewhere, check all your wires that were moved at all if any have been torn or anything and might be touching either another wire that is ground or some metal that is gorunded then that is your problem
good luck
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old 02-11-2005, 05:09 PM
Hybrid_eg's Avatar
Default checked
I checked all I could think of and found everything looking good..Also we put 5 gallons in the tank and it's still reading empty...WTF?
ReginaVagina
Old 02-13-2005, 01:34 PM
superhatch69's Avatar
there is a ground under the seat on my eg hatch driver side i have the same problem my .o2
Old 02-14-2005, 05:19 PM
Hybrid_eg's Avatar
didn't know they had grounds under the drivers seat...mine are all under the hood.
ReginaVagina
Old 02-14-2005, 05:22 PM
90LudePunkFl's Avatar
I had to run a ground from my battery to the engine block. I need to get new ground wires the stock ones are really bad on my car.
Old 02-19-2005, 03:19 PM
Hybrid_eg's Avatar
okay, on the brake lights, the button is broken, had to take it apart to figure that out. the only problem that's left is the fuel pump. it doesn't appear to be turning on and IS READING EMPTY with 5 gallons in the tank...the car sat for 3 years (LONGGG TIME), could the floater be not floating anymore?
ReginaVagina
Old 02-19-2005, 03:46 PM
I'm Awesome
lead's Avatar
test the voltage to the wire, if it shows voltage and your fuel pump still doens't turn on then replace fuel pump and replce floater while you are there
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Clint
04-13-2004 06:29 AM
onefastcavyz24
04-04-2004 04:14 PM
SteelGrey6i
6
02-06-2004 04:39 AM
Quick Reply: Oops??
