American Iron Tech A haven for those who love classic American muscle cars
How To Measure Wheel Bolt Pattern, Width and Rear Backspacing
Old Feb 15, 2019 | 03:16 PM
Default How To Measure Wheel Bolt Pattern, Width and Rear Backspacing
How To Measure Wheel Bolt Pattern, Width and Rear Backspacing=centerHow To Measure Wheel Bolt Pattern, Width and Rear Backspacing[img][/img]=leftThere are three important measurements to be considered before buying racing wheels. These measurements are to identify the wheel bolt circle (or bolt pattern), the wheel width and the wheel offset (or rear spacing). Follow these steps to ensure that you purchase the correct wheels for your application.=leftMeasuring Wheel Bolt Circles:
  • For 4-Lug Wheels measure center to center of the 2 holes that are diagonally across from each other
  • For 5-Lug Wheels measure from the back of a hole to the center of the second hole, skipping the next hole
[img][/img]=leftMeasuring Wheel Width:
  • Wheel width is determined be measuring the distance between the inner edges of the rim beads.
[img][/img]=leftMeasuring Wheel Rear Spacing (Back Spacing):
  • To measure wheel rear spacing (or backspacing), place the wheel face down and lay a straight edge across the back of the wheel and measure down to the mounting pad of the wheel to determine back spacing.
  • A lot of people refer to this measurement as offset but Offset is measured from the center of the rim. So a 8" wide rim with a 3" back spacing has 1" of Negative offset.
Chassis & Suspension Tech
Nov 7, 2019 01:07 PM
TIRES & Misc ( NO RIMS )
Feb 15, 2019 03:19 PM
D-Roll
Dec 20, 2007 08:56 AM
suprapimpa
Jul 28, 2006 05:34 PM
