Wheel Spacers ??
Old Dec 19, 2007 | 06:17 AM
D-Roll's Avatar
Blasian Sensation
Question Wheel Spacers ??
Anyone use universal wheel spacers? I saw some at PepBoys for $8 each which were 5/16" thick and made by Rally. I didn't like how the holes were a lil big and looked like if used, could result in unbalanced wheel vibration. I've seen some wheel spacers online that are direct fit to your specific bolt pattern. What do you think? Thanks in advance!
Old Dec 19, 2007 | 01:07 PM
JonLGT's Avatar
Just for decoration
Ive got 4 8mm spacers I will sell for $20. 5x114 bolt pattern.
Old Dec 19, 2007 | 03:21 PM
Like you, I prefer wheel spacers without such big holes,
although pieces can be made that will center the spacer
on the studs. You might try sliding some rubber hose/same
thickness as the spacer, over the studs to center it...................not perfect, but better than the big holes with spacer offset/out
of balance.-Bob
Old Dec 19, 2007 | 07:29 PM
HeavyChevy3800's Avatar
405hp=SLOW
I have those on my car. Purchased them from NAPA for $21.99. I tried centering them the best I could while putting the wheel on and holding the wheel in place with two lug nuts. Biggest pain in the ass. It was last minute and I'm still shopping for some better ones. Normal driving and highway seems fine. Anything over 80+mph I feel a small vibration. I would look for some with a smaller bolt circle and correct center bore.
Old Dec 20, 2007 | 04:01 AM
D-Roll's Avatar
Blasian Sensation
Ok thanks a lot fellas! My theory was right, so I'm glad I didn't buy those from PepBoys.
So they are fitted exact? Pics? PM'd
Old Dec 20, 2007 | 07:44 AM
RedPhoenix's Avatar
Won't fake the funk.
Get H&R's....
MK3 Supra - 1uzfe, Quantum Manual Swap, HX52 Billet Comp, Enkei NT03+M, JIC Reclineables... etc...
Golf TDI Diesel - 45+mpg's
Old Dec 20, 2007 | 08:33 AM
RXmotors's Avatar
Go with the hub-centric ones. I carry Ichiba spacers. Here is a link.
https://www.tamparacing.com/forums/r...-mm-25-mm.html
Thanks
Charles
Doug
813-873-2235
dhulburt@rxperformancemotors.com
Old Dec 20, 2007 | 08:56 AM
D-Roll's Avatar
Blasian Sensation
Thanks
Charles
Thanks pm'd
