help gsr smoke high rpm
My gsr runs good it started to smoke at maybe 5 rpm and up Idk y it doesn't over heat at all it is white smoke it isn't antifreeze Idk wat it is car doesn't lag it runsgood even when it smokes but it smoke a lot when u get on.it Wat could it be ? Piston rings ?
Is the car consuming any oil or antifreeze? Take the spark plugs out and compare them to see if you see any physical difference in them. You can also buy 4 NGK spark plugs and put them in and compare them in a week. Open your oil cap with the car on and see if you have a lot of blow-by (a lot of blow-by would indicate worn out piston rings).
