Chassis & Suspension Tech Cages, braces, suspension set up and more
Taking a Delta Wing through Tech
Old 10-16-2016, 02:20 PM
Default Taking a Delta Wing through Tech
https://www.youtube.com/watch?v=BR7J_PuBcfg
Before the DeltaWing Coupe can head out onto the racetrack during a TUDOR Championship event, it must first pass IMSA technical inspection. IMSA looks at two main areas: Conformity to the homologation and continuity race to race.
Tech Inspection can be broken down into four main stages:
Safety: The harnesses, fire extinguishers, kill switches, and labeling are all checked. Separately, expiration dates are checked on all driver and crew fireproof suits, underwear, shoes, and helmets.
IMSA Regulations: The dimensions of the car are measured to make sure they are smaller than the maximum, and the car is weighed to make sure it is above the minimum. On track, officials monitor the rpm and boost levels.
Fasteners: The car is checked, inside and out, for any unsecured components, especially hoses, electrical cables, and belts that might chafe and fail.
Scoring: All driver helmets are tested to make sure the right name is transmitted and received to timing and scoring. The position lights are run through a test cycle to check for bad LEDs.
Old 02-27-2017, 01:16 PM
More delta wing is here:
https://www.tamparacing.com/forums/ph...ml#post9388077
02-27-2017 02:34 PM
Nissan/Infiniti Tech
02-29-2016 07:49 AM
01-17-2016 03:21 PM
RoadRacer
Nissan Lounge
6
03-28-2012 11:58 AM
LaserCobra
09-30-2005 07:12 PM
Quick Reply: Taking a Delta Wing through Tech
