fuel issues in swap
Old Mar 20, 2012 | 03:35 PM
b13steve's Avatar
Default fuel issues in swap
d16y8 in wagovan. converted mpfi, ecu jumper......car runs with pm6 ecu but throws codes 4 and 8. plug the jumper and the po6 in, and nothing. has spark but no fuel. i have 12v to the resistor wire and no pulse to injectors. ( if i spray ether in it it runs ). checked injector wiring on jumper and they are in place. so wtf!? im lost on this one. so input is appreciated. using the jumper till i have the extra cash to go see sutton to get wired obd-1. but need the car running like a week ago
JDMinnovations hollywood, fl
93 del sol.....z6 on 8psi......201...daily beater
91 talon tsi.....25psi.......467...weekend sleeper
I do DP to MP swaps and full obd-1 for EF
352-364-6384
Old Mar 20, 2012 | 09:32 PM
What are codes 4 and 8?
What have you done to insure that fuel has pressure all the way from the tank to the injectors?
What wire is supposed to send a pulse to the injectors?-Bob
Old Mar 25, 2012 | 01:29 PM
b13steve's Avatar
checked the jumper and crank and cyl. position were backwards. thats what the codes were bob. thanks for the insight though!
352-364-6384
juicinrexls87
Jun 8, 2007 05:22 PM
Gringo003
7
Dec 5, 2006 11:50 PM
SnkEatr
Nissan/Infiniti Tech
May 14, 2004 10:30 AM
Cronic
Power Adders
Jan 21, 2004 11:15 PM
Cronic
11
Nov 7, 2003 12:55 PM
