ecu fuse keeps blowing in my acura what could it be car wont start now
Old Jul 24, 2011 | 10:43 AM
jdmtegra's Avatar
Default ecu fuse keeps blowing in my acura what could it be car wont start now
ok i have a 97 teg ls vtec obd2 p72 ecu and its been running like a champ untill today the fuse under the hood blew and everytime i put a new 1 it just blows what could this be. ive open my ecu no burnt smell or damage i dont know what it could be help please
Old Jul 24, 2011 | 11:29 AM
ALL-JDM's Avatar
Have someone look at the harness and see if there is short some where. Which fuse is blowing out?
Old Jul 24, 2011 | 04:19 PM
jdmtegra's Avatar
the 15a under the hood thats for the ecu it first happend when i hit vtec around 7k then i put a new fuse in and drove home and now it wont start again and the fuse keeps blowing
Old Jul 24, 2011 | 04:33 PM
ALL-JDM's Avatar
Check the fuse connector, see if there are any burn spots.
Old Jul 24, 2011 | 05:54 PM
jdmtegra's Avatar
i messed with the injector wires moving them around and put a new fuse in and it started up then as it was running i barley pulled on the injector wires and it blew the fuse so i am thinking there might be a rip in one of the wires that causeing this so ima go check tonight and ill get back to you . but do you think that would cause it
Old Jul 25, 2011 | 06:54 AM
BoostedRacerDad's Avatar
Pops
What is the fuse number?
[TABLE="class: tborder, align: center"]
[TR]
[TD="class: alt1"][/TD]
[/TR]
[TR]
[TD="class: alt2"][/TD]
[TD="class: alt1, align: right"][/TD]
[/TR]
[/TABLE]
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jul 27, 2011 | 06:24 PM
60-1EK's Avatar
Engineer at the source
Power wires on the injectors are grounding out. This is normally the cause for the FI/ECM fuse to pop. Essentially, look at all your YEL/BLK wires for shorts.
JESUS SAVES
9.69@151 Street Car
JKOBD
Thatguysstuff
Sep 7, 2010 10:53 AM
TurboMe
Jan 5, 2007 12:00 AM
streetfusionracing
Jul 18, 2005 04:46 PM
Jaso0on
Jul 15, 2004 01:01 PM
