svo 2.3 turbo questions
Old Jul 23, 2011 | 10:41 PM
im_DTF's Avatar
the 1 N only
Default svo 2.3 turbo questions
I got offered a 93 coupe with the svo 2.3t motor. ported head, boost controller, slicks/skinnys on weld rims. 8.8 rear, 393 gears, spool,5 speed for my jeep.
Car is pretty clean, nice interior. MY question is I dont know anything about those motors. Are they worth having, Put down decent power? Or should I pass up the trade and try to get one with a 5.0? Any common issues to look for if I go check it out?
any input would be great. Im supposed to meet him tomorrow but its a two hour drive so i want to make sure im not wasting my time
Old Jul 24, 2011 | 12:54 AM
ChicoVTEC's Avatar
cast iron block, the heads suck at flowing but yours is ported, great motors, get a cam they made more hp stock in the '80s then a 5.0 id say 350to400hp is possible with a turbo upgrade
TRHighSocietyKrew#420
Old Jul 24, 2011 | 01:08 PM
DarkBuddha's Avatar
Registered User gone bad
I have an XR4TI, which has the same motor. They are strong motors with heavy iron blcks and cranks, and if it's the original turbo motor, it came with forged pistons from the factory. The heads do suck, but can be ported to make plenty of power, or you can step up to an Essy head or do a Volvo 16v head conversion if you're really hardcore. The motors can make 300hp with bolt-ons (stock long block) using stock (35 lbs.) injectors. There's plenty of support and aftermarket for the motor... check out Boport for some killer heads, cams, manifolds, etc. 400-500hp isn't unheard of with these motors on the stock short block too. It just takes the right turbo, the right head, the right cam, standalone management, the right tuning, the right... in other words, money. And SVOJohn, one of the better known and highly experienced tuners for these motors lives down in Ft. Myers. BTW, his SVO absolutely rips.
Now, when you go look at the car, see what ecu it's using... ideally it'll have one that says "PE" (the best stock ecu), though you might also see TE, PK___, LA___, or 8UA. Anything other than the PE, LA___, or 8UA, and you'll probably wanna upgrade (unless it's been Superchip'd).
Now as for whether you should hold out for a v8 car, that's a good and fair question. There is something addictive about a boosted 4 cyl (or any boosted motor for that matter), but if you are a V8 torque kinda guy, then hold out for a V8.
Wyatt
founder Sarasota Area Car & Driving Events (http://srqcde.com/)
'70 Mustang Mach 1 || '89 Merkur XR4RS || '13 Focus ST
Old Jul 24, 2011 | 02:38 PM
im_DTF's Avatar
the 1 N only
well i went and checked it out today. turns out it was a rebuilt title and i didnt know that. i still would of brought it home but it wasnt running right. It was cutting out. So i drove my jeep home. I was kinda pissed i drove two hours to look at it. thanks for the input though
purple87lx
Jun 15, 2010 07:12 PM
Jordan T
Power Adders
13
Mar 18, 2009 08:50 PM
Mierski
Mazda Tech
6
Oct 31, 2005 11:07 AM
BucsFanatic59
Jan 18, 2005 11:43 AM
hondaspeedquest
Sep 19, 2004 10:06 AM
