Sponsored by: CARiD
T04 turbo questions.
Old Mar 18, 2009 | 05:35 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
Default T04 turbo questions.
ok heres the deal, running a to4 turbo on a 2.3t swapped ranger. it lags SUPER bad, doesnt even create boost in 1st and hits usable boost in late 2nd gear. i dont know the exact specs of the turbo (AR) or anything but it seems like the turbine housing is WAY to big compared to the compressor housing. the turbo system works completely fine, no leaks so i know its not that. is there any kind of mods i can do to the turbo to get a faster spool? smaller turbine housing, bigger compressor wheel?
heres the turbo.
Old Mar 18, 2009 | 05:59 PM
Boostin'Xr4's Avatar
Can you dig it?
Your EBR has got to be super low with that, so the EGT's must look nice.
Honestly? A 50 to 75 shotshot out of the hole. I had a smililar turbo on my Xr4 with the 2.3t and I used a 75 shot to spool it.
If you want faster spool on the street, ditch that turbo.
That's a ~1.2 A/R turbine housing, it's huge. With that wheel you don't have many options of smaller hotsides.
A big turbo stang and a big turbo truck.
Old Mar 18, 2009 | 06:43 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
so no compressor housing options with this turbo? will any "T" turbine housing work? im looking to drift this truck and spray wont be an option. im thinking i might just pick up a T3/T4.
Old Mar 18, 2009 | 06:58 PM
Can you dig it?
It looks to be a T04b, possibly a Vtrim. Let me go through some of my old AirResarch notes.
Just get a .50 trim.
I get 5psi by 2400 and 30psi by 3400rpm. Power comes on HARD.
Old Mar 18, 2009 | 07:27 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
its a to4e im thinking. im gonna explore some turbine housing, compressor wheel options. its running 15psi off the wastegate right now. hopefully with a boost controller and some turbo mods or new turbo i can unlock some potential. i think a ported T28 with a external wastegate, vband turbine housing would kick ass. the trucks so light 320whp and a decently quick spooling turbo would be awesome.
Old Mar 18, 2009 | 07:29 PM
Can you dig it?
Do you have a picture of the compressor housing for me? I can tell you in 30 sec.
Old Mar 18, 2009 | 07:34 PM
Can you dig it?
That turbo has a distinctly flat-topped turbine housing more common on To4b's.
Old Mar 18, 2009 | 07:36 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
best i got
Old Mar 18, 2009 | 07:37 PM
Can you dig it?
best i got
I'm almost ce4rtain that is a V-trim compressor wheel.
The fins are at a very sharp angle and very close together.
Old Mar 18, 2009 | 07:56 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
so where does that put me?
