Not starting??
Old Feb 9, 2011 | 08:17 PM
kober's Avatar
Don't Drink And Drift
Question Not starting??
Hey I have a 98 Integra GSR... And I have no idea wtf is wrong with my car.
I checked battery, checked terminals, tried jump starting, push starting. I checked my fuel pump... I switched the main relay.. When I put the key in and tried starting it.. no dice. Doesn't crank or anything, but radio, lights, etc turns on.
I want to say it's one of my fuses? But do you know which one would affect the car with starting?
Oh btw, It happened randomly.. the not starting problem. I went to Best buy in the morning.. then I went to fill up gas. and when I tried starting again. Nothing.
Any help will be appreciated. Thank you.
Will rep for any information.
TB Bucs Fan
ORL Magics Fan
USF Bulls Fan
__________
92 Accord - Traded
89 B16 Crx - Sold
92 S13 Hb - Traded
96 S14 SE - Traded
93 S13 Hb - Sold
95 S14 - Sold
97 Accord - Current DD
Old Feb 9, 2011 | 08:37 PM
BoostedRacerDad's Avatar
Pops
try this
Turn key to on position
Take a piece of wire and run from Positive on battery to small solenoid wire on starter. Make sure to take small wire off of starter and just touch wire to where it went. Let me know if car starts we can go from there.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Feb 9, 2011 | 08:43 PM
kober's Avatar
Wait, what wire? Any kind of wire?
TB Bucs Fan
ORL Magics Fan
USF Bulls Fan
__________
92 Accord - Traded
89 B16 Crx - Sold
92 S13 Hb - Traded
96 S14 SE - Traded
93 S13 Hb - Sold
95 S14 - Sold
Old Feb 9, 2011 | 08:49 PM
Pops
Yes 12 gauge would be fine or what ever you have. You will just be triggering the solenoid on the starter.
JoKie TuNinG
StricKlyMT
727-510-6301
Old Feb 9, 2011 | 08:51 PM
Pops
If you dont understand PM your number I will walk you thru it.
If car started right up check the clutch interlock switch on top of clutch pedal. to bypass switch jump the two wires together. Dont mess with the lower switch it is for cruise control.
If car didnt start or crank, bad battery or bad starter.
good night
JoKie TuNinG
StricKlyMT
727-510-6301
Old Feb 10, 2011 | 05:20 AM
flatrex's Avatar
crx hatch sedan
+1 on the clutch switch
Old Feb 10, 2011 | 10:37 AM
HONDACIVIC95's Avatar
could be fuse box by the battery
eg hatch!!!! current
Old Feb 11, 2011 | 01:47 PM
kober's Avatar
ok i did the wire to starter thing.. and it doesnt work.. what do u mean by jumping two wires by the clutch?
Old Feb 11, 2011 | 03:16 PM
sburtoncivic98's Avatar
Ok when you jump the two wires on the clutch it lets you start the car without the clutch being engaged. You can use a paper clip, curve into a " U " shape, and stick both ends inside the clip, the bypasses the clutch safety switch. Also sounds like you have a bad alternator, if you cannot pop the clutch and get it going, that tells me theres no output on the alternator. Also their is a anti-theft device, and if was not working properly, it would crank and not start,which rules out that, but like you said it does not crank at all. One other thing you could do, put the car in neutral, pull the ebrake, take a screw driver with rubber at the end and touch the screw drivers to both terminals and let me know if it starts
TR "Old Skool EF" Member #210
94EGgirlie
Jun 27, 2010 07:19 PM
customkid72
Oct 9, 2009 02:31 PM
MITSUracer
Jun 17, 2009 05:08 AM
oldandbusted
Sep 20, 2005 11:56 AM
_Charles_
Aug 26, 2003 01:30 PM
