car not starting
Old Sep 19, 2005 | 07:22 PM
oldandbusted's Avatar
Default car not starting
car is 89 hatch with b18 in it ran but now just wont start up will turn over but will not start i have tried ecu actually 3 diff ones,fueses are good,getting fuel what do you guys think this could be?
Old Sep 19, 2005 | 07:23 PM
TampaTraps's Avatar
get big or die trying!!
is it a five speed, ifso try push starting it, and are you throwing any codes? check spark in each cyl. check for a clogged injectors, check grounds, check teh spark pugs and wires.
that's president hussein obama to you :gordy:
Old Sep 19, 2005 | 07:41 PM
new plugs and wires,injectors are good,no codes ........car will run one day then not the next pushing it doesnt work but when pulled by a truck and put in gear it will run very odd
Old Sep 19, 2005 | 08:23 PM
freakasis's Avatar
if a car can push/pull start it and you cant then its because your not doing it right. when you do push/pull start it will it run everytime? or just sometimes? have you checked for spark?
Old Sep 19, 2005 | 08:35 PM
will check for spark in morning
Old Sep 20, 2005 | 11:56 AM
found probem rotor was loose and the bolt was broke off
