one problem DIRECTLY after another
Old Oct 23, 2010 | 01:13 PM
Superwes98's Avatar
Default one problem DIRECTLY after another
so i went to pull my car out of the drive way to let my brother in law leave and when i went to start my car the starter stayed engaged. so i turned it off but it kept tryin to start so i turned back on and left it running so i could let him out and to pull into thee garage.
i turned it off and tried to turn it back on and it wouldnt even turn over.
i swapped the starter solenoid on the fire wall and checked connections. also checked my starter switch under the steering column and nothin happens.
but when i try to turn the car on then turn the key back i hear a ping from under the hood, BUT ONLY WHEN I TURN THE KEY BACK.
I have a 92 gt with an older starter, so i have the big simple one.
i really need some help, my car has been nothing but trouble with problem right after another. i will take anyones smart ass $0.02 right
Old Oct 23, 2010 | 01:40 PM
Superwes98's Avatar
tried to do the screw driver trick, connecting the positive and negative on the solenoid, but it didnt even spark
Old Oct 23, 2010 | 01:54 PM
SVT1996Cobra's Avatar
What?
so you moved the car with the starter still engaged?
Old Oct 23, 2010 | 02:08 PM
Superwes98's Avatar
i had to, my drive way is on a slant
Old Oct 23, 2010 | 02:32 PM
Superwes98's Avatar
come on people i know u all have some input or even know my problem
Old Oct 23, 2010 | 02:41 PM
Stoopid Wendy's Avatar
see dick run
I don't see it being the starter, if it's the big old style. Most of the time low battery voltage burns the soleniod contacts and makes it stick. You replaced the soleniod and wired it right?
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Oct 23, 2010 | 03:34 PM
Superwes98's Avatar
yes sir. i changed to the older style about 5 months ago so thats not the problem.
and i have a optima red top that i check weekly and it still has charge. so thats not it either
Old Oct 23, 2010 | 03:52 PM
Superwes98's Avatar
when i turn the key, all i get is one tick for each time i turn the key from wat sounds like the fender wall solenoid
can the ignition switch cause it to do this
Old Oct 23, 2010 | 04:08 PM
Superwes98's Avatar
or could i have killed the starter when i was running it
Old Oct 23, 2010 | 05:56 PM
DrDirt's Avatar
Team Geritol Racing
Make sure your starter solenoid is a real live FORD made part. Crap from Autozone etc. tend to weld their contacts together of a regular basis. True story.
On the flip side, the real live FORD made ignition switch on the column, not the one you stick your key into, is a total POS in it's original form. If it has never been replaced...even with an Autozone one, now is a good time to do it. They are cheap. The original ones are dangerous. More than a few 80's and 90's Fords have burned up just sitting in the driveway.
YO! Barry! You LOST!
