need help with my 1991 dx hatch asap! please!!
Old Jul 12, 2010 | 06:37 PM
travishoward's Avatar
Default need help with my 1991 dx hatch asap! please!!
ok, so i have a 1991 civic hatch, dx, that ive done auto to 5 speed swap, and dpfi to mpfi swap to
im having a problem, with the fuel i believe
ok, so i got the mpfi wired up, the car worked, but was sluggish, and hesitated, then just got worse, eventually, burned up a sparkplug wire, number 3, and then after i changed that, it ran, then burnt another one, and wouldnt start (i drove it around for like 30 minutes), this time it burnt #2, so i figured maybe my wires were weak, so i bought some duralast ones, the high heat whatevers, and new sparkplugs, ngk platinums, then it started up, and rev'd fine for like 30 seconds, then as i got in the car, tried to drive off, it died, wouldnt start back up, finally, it did, and it would bog down and die when i gave it gas, so we decided it was the dizzy that had went bad, so i bought another one, then it cranked up fine, and rev'd fine, and yet again, when i tried to drive off as soon as id let off the gas this time, it would die, now its doing that same thing, so i thought it may be my fuel filter, changed that out, still does the same thing, so im thinking its my fuel pump, and when i listen for it, it doesnt prime, so i replaced the fuel pump, tested it, it primed, put it back in the tank, and it stopped priming, ive taken it out, and checked both positive and negative wires, theyre on properly, yet it still wont prime
car still starts however, i just have to give it gas when i crank it over, and then i have to hold the gas in, otherwise it dies, ive tried readjusting the throttle cable, just incase, but that does nothing, ive advanced, and retarded the dizzy, that doesnt do much either
i have no idea what the problem is, my buddy says i could have a vaccuum leak, another says thier could be a bad ground? and yet anotherr says that i just need to clean out my injectors
i need help, this is my dd, and it seems everytime i pay for insurance, it does this crap, so i never have a running car, after making a near $400 down payment
someone has to have had this problem before, or just be smart enough to know whats wrong
PLEASE help me get this thing driveable
Old Jul 12, 2010 | 07:31 PM
Thatguysstuff's Avatar
Hey its that guy!!
main relay?? have you checked it??
running the right ecu? any Cel???
Old Jul 12, 2010 | 08:10 PM
i havent checked that yet, not sure how, i heard theirs 3 different ones?
and im using the right ecu, its a pm6, and my dash lights dont work at all, but the ecu itself is flashing 13
Old Jul 13, 2010 | 09:36 AM
bump, i need help
Old Jul 13, 2010 | 10:47 AM
RhinoFLA's Avatar
Do it big.1 life to live.
Like he said ^^ any check engine lights? definitely sounds main relay related.
Old Jul 13, 2010 | 10:51 AM
sxysweed's Avatar
CRX.XXX
Main relay is behind the change box, straight up from the hood release. Take the change box out, and there's a bolt that holds it to the body. Pain in the ass to get to. take it out, pop it out of it's case, and re-solder all the joints.
RhinoFLA's Avatar
very helpful stuff here
Honda Acura Ignition (spark) Troubleshooting - How to
Old Jul 13, 2010 | 10:55 AM
integra's Avatar
90% grind 10% sleep
multiport is done correctly?
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jul 13, 2010 | 11:16 AM
i couldnt just buy a new main relay?
and thier is a cel code, its a 13, on a pm6
i cant find a cel code sheet for the pm6 anywhere
and yes mpfi is done correct
i got the fuel pump to prime, however, its still doing the exact same thing
Old Jul 13, 2010 | 01:42 PM
RhinoFLA's Avatar
When you switch the ignition to on does the check engine light come on then go off after a few seconds? If so then it's the main relay. They're about 60 bucks, if you've got money to blow buy a new one.
