change timing belt?
Old May 30, 2010 | 12:29 PM
nicklemore's Avatar
Default change timing belt?
im changing my timing belt but cant get the crankshaft to lock down. I read of a thread that you just have to put the car in 5th gear and have someone press on the brake and that will lock the crankshaft so i can remove the pulley. but its not working. Is there another way of doing this, also its not coming off with a impact gun.
Old May 30, 2010 | 01:33 PM
StreetBlitz's Avatar
B Tuned CRX
PB Buster=WIN
Old May 30, 2010 | 01:43 PM
nicklemore's Avatar
yeah i tried that
Old May 30, 2010 | 01:49 PM
FrodoGT's Avatar
Found the Vtec switch.
Yeah putting it in gear should work..but really you should be using the pulley tool that is meant for this.
TR Old Skool EF Crew #24
Old May 30, 2010 | 01:52 PM
nicklemore's Avatar
i was just going by this thread. Timing Belt and Water Pump Replacement on a G3 Teg - Team Integra
Old May 30, 2010 | 01:56 PM
nicklemore's Avatar
the only pulley tool i kno if the one that is used to actually pull the pulley off. I need to take the bolt off 1st
Old May 30, 2010 | 02:33 PM
Jerome's Avatar
GOOD Impact gun ?
Old May 30, 2010 | 04:27 PM
nicklemore's Avatar
my brother taught me a trick bout using a nylon rope and taking a spark plug out. so that the piston doesn't come up all the way. It worked. so thnk for the help
Old May 30, 2010 | 04:37 PM
sovlisky's Avatar
I have always used a flat head holding the flywheel in and a breaker bar with the jack handle for leveage to get them off
Old May 30, 2010 | 05:51 PM
nicklemore's Avatar
yeah that works, but the engine is still in the car
