any 3sgte specialists around ??
Old Apr 30, 2008 | 11:03 AM
MR Dizzle's Avatar
That's right bitches !!
Default any 3sgte specialists around ??
hello, i dont post here much, but i am currently building a 3sgte w/ a td06 kit for my MR2. so the motor is almost completely together, but after reading all the write-ups and watching all the videos of how to set timing, it still confuses me. This is my first time building a motor, and i dont want to attempt setting timing if i dont know anything about it. so if any "3sgte specialists" would like to swing by and do this for me, i would really appreciate it. of course i will pay in the form of cash and beer . let me know,
navin
Old Apr 30, 2008 | 08:17 PM
christo4_99's Avatar
there is a mark on the bottom timing gear that you can line up without the cover or harmonic balancer on(line it up)now take your 14 mm wrench and use it to put the exhaust cam in time(there is a bend in the timing cover baffle for each gear)...there must be no slack in the belt on the right side you may have to "grab" the belt with the exhaust cam gear and pull it tight then let it slip til it's in time...now with the right cam gear in time,and maybe a clothes pin or a little spring clamp holding the belt to the gear time the intake cam in without moving the other one(no slack in belt across the top of the two gears)...clamp it or whatever as before then install the tensioner with the granade pin in it.release the granade pin...spin the motor clockwise to the next top dead center #1 and check to see if your timing marks are still on the cams and if they are you're good....if not repeat and make sure you take up the slack in the belt this time...if you are not sure you can wedge something in there to hold the tensioner over and rock the motor timimg back and forth with a 14 mm wrench and a 19mm wrench with the bottom pulley bolt in(to check alignment) cuz the tensioner can be a bitch to reload
the way i see it,if you combine two words,like bull and shit...well,you know the rest
Old Apr 30, 2008 | 08:24 PM
CelicaTech - 3SGTE Engine Reseal look at the last pic
Old May 1, 2008 | 10:45 PM
MR Dizzle's Avatar
cool, thanks man. that actually helped me to understand it a lot. but i dont have OEM cam gears, i have fidanza cam gears. would i need the oem ones to line everything up, or how can i go about setting timing with the aftermarket cam gears ? thanks.
Old May 8, 2008 | 10:48 AM
the adjustable cam gears,when set on zero,are the same as the stock cam gears...
Old May 8, 2008 | 11:08 PM
MR Dizzle's Avatar
oh... lol i guess i will attempt it within the next two weeks. thanks for the help
Old May 19, 2008 | 09:15 PM
SangH's Avatar
Are you installing stock cams? I hope so. If not, you'll want to set your cams to your cam card spec, take it to the dyno and fine tune the adjustable gears.
Old May 20, 2008 | 08:24 PM
MR Dizzle's Avatar
yep, stock cams w/ fidanza cam gears. i haven't had time to attempt it yet cuz of this freakin trig class, but i will soon. btw, mcs is the shit ! got my stage 2 head from them
Old May 21, 2008 | 08:20 AM
SangH's Avatar
Thanks! It's always nice to hear feedback.
-Sang
Old Jun 9, 2008 | 10:23 PM
flyspyder55's Avatar
give me a call some time, ive spent plenty of time with the 3s
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
