need help fast 90 si
Old Mar 20, 2008 | 12:58 PM
efhatchetman86's Avatar
Damage inc..x
Default need help fast 90 si
my hood was left open last night when it rained and now car issues of course. the car starts up alright i made sure there wasnt water in eney key parts but when i hit the gas she bos down and shuts of i cant figure it out. theres no engine light on but the ecu is flashing 7..9..1 eney help would be app. thanx alot ive been haven bad luck this month with this damn car...
DAMAGE INC..x
Old Mar 20, 2008 | 01:06 PM
AccordTypeR's Avatar
well 7 is yout TPS which is throttle position sensor, 9 is your number one position sensor, and 1 is heated O2 sensor #1, sounds to me like te water is causing some electrical issues
Old Mar 20, 2008 | 01:10 PM
Damage inc..x
im gonna try and pull all the plugs and blow them clean and see what happens...
DAMAGE INC..x
Old Mar 20, 2008 | 01:21 PM
FrodoGT's Avatar
Found the Vtec switch.
Umm..the 90 doesnt have a heated o2 sensor. And the ecu would blink them in order 1..7..9..........repeat. Sounds like you may have gotten water into your distributor. Also the tps would certainly cause this kind of chaos. The o2 code will often get thrown just because the engine is running funny, in limp mode and usually WAY too rich.
TR Old Skool EF Crew #24
Old Mar 20, 2008 | 01:43 PM
Damage inc..x
thanks man i pulled the plug on the dis. and water poured out im leting it all dry out now will see what happens..x
DAMAGE INC..x
Old Mar 20, 2008 | 02:18 PM
Damage inc..x
well not eney better now its throwin 1..8..9 ?
DAMAGE INC..x
Old Mar 20, 2008 | 02:26 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
Water poured into your motor??? Light a blow torch and stick it down there for a few seconds.
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Mar 20, 2008 | 02:29 PM
Damage inc..x
oooooooook are you for real?
DAMAGE INC..x
Old Mar 20, 2008 | 02:55 PM
02ep3turbo's Avatar
dont listen to the blow torch thing you will warp something in the motor torches directly on metal parts is no good
Old Mar 20, 2008 | 03:02 PM
Damage inc..x
oooo well what the hell should i do....
DAMAGE INC..x
