spark cut
Old Dec 19, 2006 | 10:33 AM
95GST's Avatar
boost is your friend
Default spark cut
jw if any one knows what are some things that can cause spark cut
Old Dec 19, 2006 | 12:20 PM
cornflake's Avatar
813's Finest
fuel cut? check boost leaks
Old Dec 19, 2006 | 03:41 PM
95GST's Avatar
no its not getting fuel cut its losing spark and running rich
mitsu420aT's Avatar
i would say bad coil or wires
or bad engine ground
Old Dec 19, 2006 | 06:45 PM
Brothers's Avatar
TR Balla Donor Supreme
what heat range plug are you using and how much boost
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
Old Dec 20, 2006 | 10:14 AM
95GST's Avatar
ngk bpr7es and about 20 psi
Old Dec 20, 2006 | 10:19 AM
cozmo's Avatar
obviously try new plugs first, but what are the conditions of the missfire? rpm, only under boost?
I used to have problems with plugs backing out of the head which would cause misfire issues in that cyl.
Wires, plugs, coil pack, too rich via afc or bad fpr. Lots of things really.
Old Dec 20, 2006 | 10:23 AM
95GST's Avatar
it only does it under boost at about 4500 rpm the plugs are less than a month old
Old Dec 20, 2006 | 10:25 AM
cozmo's Avatar
Check to make sure the plugs are all tight in the head. Sounds like one may have backed out in that month time. That's what I would do next as its free.
