integra problems
i have a 95 integra gsr that was just freshly rebuilt. the motor starts but it boggs out and dies and the rpm gauge bounces everywhere. engine light doesnt turn on and i dont know whats wrong. if anyone has an idea of what it could be let me know
check all vacuum lines for leaks, check gaskets for leaks. Mine was a leak between the throttle body and manifold.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
Could be some sensor wires crossed, but highly doubt that.
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
To the original poster, there could be a million things wrong with it. What else did you change....injectors, ecu, etc?
is there a ground for the transmission that hooks in to all the other sensor wiring because thats what i heard from someone else? and i didnt change nething all i did was rebuild the bottom block and put it together
my friend just swapped to a b20 and had a similar problem, all it was, as a bad spark plug.. check that and wires.. could be that simple.. that or it may also be vaccuum lines.. or bad sensor..
