Cam
Old Sep 3, 2006 | 04:07 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Default Cam
I got the 393 dyno'd. It put up some great numbers. No I am not going to share, I don't want to deal with people saying my numbers are bullcrap. The shop the built the motor said the cam I am using isn't letting the heads breathe. I am running a Comp Magnum 280H cam with 1.7 RR's. The math comes out to .544 lift. But they said the Duration is too small. What cam do you pushrod guys use or what would you recommend?
Some specs
Performer RPM 2.02/1.64 with some port work done
393cid
Flat top forged pistons with oversized valve reliefs
About to step up to a Victor jr intake from my Torker 2
Old Sep 3, 2006 | 04:16 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Call comp have them custom make you a cam thats what i did. I went from 358 to the wheels with a lunati 544 560 to 411 to the wheels with a custom cam from them cost me 300 bucks. good luck!!
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Sep 3, 2006 | 04:48 AM
69Boss521's Avatar
Thanks man... I plan on doing the Roller cam retro fit thing.
Old Sep 3, 2006 | 05:31 AM
Stewart Scott's Avatar
"Now I only have two"
let's see 13hp for $300 or 10hp for $1000 hhmm...(comparing the thread with the honda video)
"I'll take the 13hp for $300 Alex"
Sorry to hijack the thread "boss" but had to make the comparison because I DO NOT believe in imports!
Good luck with the cam find.
God bless America!
God bless our troops!
God bless the GOP!
Old Sep 3, 2006 | 05:45 AM
Steve B's Avatar
brings his heater.
sorry, i gotta know what the numbers are.
Old Sep 3, 2006 | 06:52 AM
Na306StAnG's Avatar
roller cam is the way to go!
Largo fl 33773
MV#72427
Old Sep 3, 2006 | 08:34 AM
WOW did I do the math wrong on that! sorry for buttin my nose in.
358 to 411 doesn't equal 13! more like 53hp for $300. nice!
God bless America!
God bless the GOP!
Old Sep 3, 2006 | 09:42 AM
69Boss521's Avatar
I am still trying to learn as much as I can about the roller cam conversion for my engine. Do they sell a complete retrofit kit?
Old Sep 3, 2006 | 09:45 AM
Na306StAnG's Avatar
They do, comp can set u up with everything you need
Largo fl 33773
MV#72427
Old Sep 3, 2006 | 01:22 PM
Zman's Avatar
I gota Cheby
just remember to ask how its on the valvetrain. some rollers ramp up fast and its hard on the valves and springs. they usually make a little more power but in decline in longivity. If they dont know if it is, and they should know. rule of thumb is by the valve adjustment. Most hard hitting roller's will have loose clearance's on the valves 28 to 30 and above. smooth action rollers are tight 22 range. just a lil guidelines.
Only 1/4 mile track I know is Gandy Bridge
