Help me find this part!!!!
Old Aug 4, 2006 | 05:23 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Default Help me find this part!!!!
I want to wire my Fan and Fuel pump to come on when my oil pressure hits 5 or so psi. I knew theres a way to do it. I've had many cars that have been like that but the guys at A&E/summit Don't have a clue . They found one from NOS but its 39.99. I think you can get it at Autozone just need to know what car and year. Major thanks in advance
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Aug 4, 2006 | 06:54 AM
nasdstang's Avatar
need turbo stuff,pm me
this makes no sense
-Ronald Reagan
Old Aug 4, 2006 | 06:59 AM
$hawn's Avatar
lives in a glass house
^ Yea, you kinda lost me as to what you are wanting to do?
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Aug 4, 2006 | 07:37 AM
allibabba's Avatar
Sounds like a Hobbs switch to a relay.
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Old Aug 4, 2006 | 08:16 AM
$hawn's Avatar
Originally Posted by Just Dave
Sure it does. Basically instead of hot wiring his pump and fan to a key-on source, he wants them to be on when the engine is running.
The only problem I could see is if the car sits and oil pressure drops, the fuel pump won't turn on to prime the system until it builds some oil pressure. It may take several seconds for the switch to see the pressure, turn the pump on, prime the system and fill the float bowls.
You are correct. But you'll still need the key and power source and a relay to run those High current devices. I can see running a switch like that on the f/p to turn it off under a set oil pressure. It just sounds like there is no use for the safety switch it that application.
Old Aug 4, 2006 | 08:30 AM
jzgt's Avatar
Holley has one that I've used before -- It's part number 12-810.
- Jeff
Edit - I used it for the FP -- after reading what you want to do, this probably wouldn't work...
Old Aug 4, 2006 | 09:26 AM
Na306StAnG's Avatar
I'm not to sure whats so hard to grasp here. let me try this again.... Running a key on wire from somewhere in the car to the oil pressure switch (thats what i'm looking for) on this "switch" theres going to be to prongs one for the key on. then i'm going to run 2 wires one to each relay (one for the fuel pump one for the fan) this way when the keys on nothings working. until the car build 5 psi of pressure.
Largo fl 33773
MV#72427
