Manual boost controller?
Old Apr 19, 2005 | 05:45 PM
Road Rage's Avatar
Shake n' Bake
Default Manual boost controller?
Anyone know if it is the dial is screwed all the way in if that is low boost or high boost? im pretty sure low but just wanted to check and see....
Old Apr 19, 2005 | 05:56 PM
dsm_90's Avatar
fast, faster, gone
hopefully you have a aftermarket boost gauge so this way you can just start dialing and having fun(at your own risk-lol), out=low and in=high...what brand of MBC is it?
frequency
Old Apr 19, 2005 | 09:27 PM
Brandon's Avatar
Resident Dingo
i thought in was low and high is out... that's how it is with the SBR and TurboXS
and +1 on the boost gauge
Old Apr 20, 2005 | 01:54 PM
NightRdnEclipse's Avatar
Ralfy
+1
-Ralfy
http://www.myspace.com/ralfy4
Old Apr 20, 2005 | 02:09 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
They are all different, all my turbo xs have been out for high and in for low.
SUCH IS THE RULE OF HONOUR.
Old Apr 20, 2005 | 02:37 PM
Ep41382's Avatar
TR Balla Donor Supreme
ya... most manual BC i've used... its the opposite of what common sense would tell you... seems like.. if the screw came out, it would rasie the boost/screw it in lower the boost.. but like i said.. most of the ones i've used.. its the opposite..backing the screw out usually lowers the boost, screwing it in should raise the boost... just be careful and watch your boost guage....have at it
Eric
AIM: Ep41382
Old Apr 20, 2005 | 05:48 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
It makes sense if you take one apart and look at the construction. In most cases by tightening the screw you're adding preload to a spring that compresses a ball bearing to seal off boost pressure until the boost pressure is high enough to overcome the spring pressure. Loosening the screw reduces the boost needed to bypass the seal and flow to the wastegate actuator.
Old Apr 20, 2005 | 06:28 PM
dsm_90's Avatar
fast, faster, gone
+1 for my MBC(joe p)in my opinion you just need to starting screwing it in and then out(sounds sexual--lol)and use your boost gauge to guide you..
frequency
Old Apr 20, 2005 | 06:37 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
well for the two homemade ones ive had, its low out high in, but then i got a turbo xs and got confused!
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Apr 22, 2005 | 04:04 PM
tampatsi21's Avatar
Ian
I Have A Joe P Bc In Is High Out Is Low
John
Power Adders
6
Apr 14, 2004 12:25 PM
Jordan Y.
Power Adders
12
Aug 18, 2003 10:26 PM
Billy
Power Adders
18
Jul 29, 2003 10:39 AM
specie
Mar 1, 2003 12:02 PM
