can someone explain
Old May 17, 2004 | 09:16 AM
20whiteboy03's Avatar
Default can someone explain
how do you hook up a second battery for just your amp? and keep it charged
Old May 17, 2004 | 03:06 PM
TBSpyder's Avatar
Either run it directly to the alternator or bridge it to the your current battery.
Old May 17, 2004 | 03:08 PM
Bumpin Expo's Avatar
Reppin' the 813
Oo0o0o yes I saw this on Trucks! Tv yesterday !!
Wire the posative to posative and negative to negative then wire to the alternator. That will keep everything 12 volts. DO NOT wire negative on one battery to posative on the other then to the alternator cuz that will cause a 24 volt load and it will blow everything on ur car that is made for 12 volt only. but yeah its not hard at all, hard to understand? ill draw a picture if u need
Old May 17, 2004 | 03:37 PM
TBSpyder's Avatar
You'd have to be a moron to wire positive to negative...
Old May 17, 2004 | 05:22 PM
TBSpyder's Avatar
Originally posted by SupraKid
Don't think anyone is that dumb.......
I just picked up one of those bad ass stinger batteries to run as a 2nd... just have to find time to mount it. It was the only thing small enough for me to work with... and god damn more expensive than an optima got to pay to play i guess
Why do you need a second battery?
Old May 18, 2004 | 12:05 AM
93ex's Avatar
Just Ledoux it!
To keep it charged, use a battery isolator or a diode, even tho a diode loses .5 volts or so.
dont wire battery to battery, that will just drain both.
Old May 18, 2004 | 05:11 AM
SSpiro's Avatar
Errare Humanum Est
Word! Beat me to it.
I'm also curious why the need for a second battery.. Even some of the most advanced or power-hungry setups can be done on a single battery. Possible that you may just need a larger alternator?
Old May 18, 2004 | 09:38 AM
i have a optima gel cell my dad gave to me and thought it would be cheaper to just hook it up instead of boosting the alt.
my car is like my girlfriend spoiled and sometimes a BITCH, but she always finds a way to make me wanna keep her
