OEM Integra Steelies with hubcaps 14"
3 tires with 50% thread....one with bad camber wear but holds air.
STEELIES SOLD HUBCAPS AVAILABLE
$ 30
954 882 7591
Orlando
$ 30
954 882 7591
Orlando
R.I.P Arthur Newton A.K.A Bingi
Bump Will Add Cash For Meshes Or Fat 5's
I don't know if you would be interested, but I can trade you a powerful laptop (works great, but bad video card. need to replace or resolider it) for your steelies. I don't need hubcap. It is HP pavilion dv5-1119nr amd dual core x64, 15.4' widescreen HD glossy screen 4 gig of ram, 250 gig hdd, window 7 64 bit, wifi, bluetooth, dvdrw, webcam, and 3 hrs battery life. just a bad video card. easy to repair it. It plays any gaming just perfect because it have 2 GB video card, but bad. Just need to resolider it. any business can get it done less than 100.
I know I don't have VTEC, but I drive LOW N SLOW.
what do you mean by resolder........did you take the card out? how did it break?
No, I didn't take the card out. from what I researched, the main reason why video card is out is because between the GPU video chip and the cooler thing is not sticking together anymore. it is dried out. Need to remove the old metal glue by alcohol and put the new metal glue on it then it will work great. It happened to all the HP laptops. I can send the pics if you are really interested. I have a phone number that will do resolider (whatever that spell) for around 100, but other business you can find will do 100 or less. I found one will do 100. it is easily $500 laptop because 2 GB video card.
