Need help w/ 02 GTI Immobilzer
Old Sep 1, 2011 | 06:57 AM
s2k FTW's Avatar
Default Need help w/ 02 GTI Immobilzer
Alright, so I just got a 02 GTI in, and the thing starts for a second then cuts off, all along with the key/car logo blinking on the cluster.
tried battery swap, touching cables to discharge, wiggling it, leaving key in ignition for 20 minutes, etc and to no avail.
To be honest, Im not sure they even gave back the correct key with the car(i mean it does crank it over). Now can someone with a vagcom check it out, or do i need to bring it to a dealer/key coding type of person?
located in port richey
Old Sep 1, 2011 | 02:46 PM
seven's Avatar
Sounds like it needs to be coded, might be able to do that with vag com but not sure.
___________________________
Blue Collar Motor Sports
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Sep 1, 2011 | 03:14 PM
Garrett's Avatar
pfft.....
if you have a second working key you can program the one thats not working without a vag-com
Originally Posted by The Tex
To program a remote:
1. Stick existing key in the ignition and turn it on (but don't start the engine).
2. Put new key in the driver doorlock, with the door closed.
3. Turn door key counterclockwise and hold until horn beeps.
4. Keep holding. Press any button on the remote in the door until the horn beeps.
5. Take keys out.
New remote is now programmed (it will be a couple of minutes before it works, though).
