monsoon ?
Old Sep 9, 2010 | 04:26 AM
sonicwrx's Avatar
Default monsoon ?
want to add a sub and amp to the factory monsoon stereo in a 05 jetta gli any advice i thought i could just use some hi/low converters but after taking a look at it i dont think its goung to be that easy
Old Sep 10, 2010 | 02:17 PM
sonicwrx's Avatar
anybody???
Old Sep 10, 2010 | 02:53 PM
seven's Avatar
there's a diy on vortex. you basically get the signal from the wiring going to the stock amp and use a line converter to get it to your amp. use the search function over there it's not hard to find.
___________________________
Blue Collar Motor Sports
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Sep 11, 2010 | 06:55 PM
Garrett's Avatar
pfft.....
ill be nice for a change... this is only because i have the DIY bookmarked
VWVortex.com - The Official Double-Din Monsoon Aftermarket Amp+Sub(s) Install Guide
Old Sep 13, 2010 | 11:47 AM
Madness's Avatar
AntiMatter
it only takes like 20 minutes max to do this, all you need is the wiring diagram, and the converter from best buy which is like 10 bucks
Old Sep 14, 2010 | 06:35 AM
Garrett's Avatar
pfft.....
yup its pretty straight forward and self explanatory but then again i used to be an installer so most any car electronics are easy for me.
