Any ideas and tips on rebuilding a 12v VR6
Old Sep 10, 2010 | 05:22 AM
G-Magoo's Avatar
July - Ride of the Month
Originally Posted by AccordTypeR
i would have to disagree on the short runner statement though, i saw huge gains with my custom short runner manifold...
Then this means nothing to someone if they're building an all motor VR. No experience using one on natural aspiration. Of course you'll see gains on a force induced VW with one.
I love haters..
Originally Posted by VR6exxy
I love your brutal honesty. It makes my day
Build thread
Old Sep 10, 2010 | 05:50 AM
VR6exxy's Avatar
They're pointless on a NA motor
I love turtles
Old Sep 11, 2010 | 05:48 AM
AccordTypeR's Avatar
im sure they are, but then again so is a n/a vr IMO, boost is the way to go, youll never make the power on N/A that could with even just a small amount of boost
Old Sep 11, 2010 | 06:01 AM
VR6exxy's Avatar
True, but slapping a turbo on is easy. Anybody can go get a kintetic kit and throw it on. It takes a lot of skill and knowledge to build a vr that puts out pretty good power. I would be more impressed with someone that built a 250hp na motor rather then just bolt up a kit.
I love turtles
Old Sep 11, 2010 | 09:00 AM
ya that would be impressive, i just dont bolt on kits though, all my setup is custom made so everything works well witht the other to make a reliable even power band, but it would be cool to see a N/A make a good amount of power, would have to be really careful with the compression ratio would be a challenge to balance the compression so you could still run pump gas and keep it streetable
Old Sep 14, 2010 | 08:48 AM
hmmracing's Avatar
dabeetereater
i would have to dissagree, i have seen a few people make some good hp numbers with a short runner, there is a guy with a hpa type mani and hes making like 225 ish if i remember, if ya have a properly setup motor and a tune it should help but u will have a pretty bad loos in torque.
i think a high compression motor with a short runner would do work
EuroRat #2+#3
"YEA THOUGH I ROLL THROUGH THE VALLEY OF THE SHADOW OF RICE, I WILL FEAR NO TURBO FOR DISPLACEMENT AND TORQUE ART WITH ME... MY RODS AND MY PISTONS THEY COMFORT ME.."
bought not broken!!!
member #2
"having a big turbo is like having a big dick; it's not immediately obvious to everyone, but you have to just rest assured that when it comes time to put it to use, you won't need to explain a whole lot afterwards"
Old Sep 14, 2010 | 10:28 AM
  #17 (permalink)
G-Magoo's Avatar
The only issue is the valve to piston clearance on high CR VR's with bigger cams. Yes a turbo VR will make more HP per dollar but it'll also break way more things than a N/A VR will. Plus factor in traction issues and a built N/A VR will keep pace with a turbo VR up to a certain point. Yes you can make over 200-220whp on a VR but its gonna require a good amount of money to make that kind of power. When it comes to making power turbo>n/a. Im still building a n/a VR over a turbo VR anyways.
I love haters..
Build thread
Old Oct 1, 2010 | 10:39 AM
  #18 (permalink)
divinevr6's Avatar
AccordTypeR you willing to post some pics and specs on your set-up
also Arizona Auto House has good prices on OEM stuff. they dont have everything but there are good prices
www.fourseasontuning.com
www.MJMautohaus.com
www.ECStuning.com
www.blackforestindustries.com
those are a few sites that will have many of the parts you will need to rebuild it.
Old Oct 2, 2010 | 01:46 PM
  #19 (permalink)
Caan's Avatar
raising the standard
Most of those commercial SRI's aren't even tuned for VR6 engines. The length of the runners, lack of velocity stacks, and overall geometry are way off. They're better for making space and visual appeal.
Mk2 vr6t chirpin' sixth...
Old Oct 2, 2010 | 07:13 PM
  #20 (permalink)
look in my garage, specs are in there, tuned on C2 software and on the dyno at 10lbs it made 338hp--328fl/lb Tq to the wheels and on 15lbs it makes just about 400
