Wheel whores i need your help.
Old Aug 26, 2010 | 03:26 PM
Garrett's Avatar
pfft.....
Default Wheel whores i need your help.
on a MK4 GTI with a 7.5" wide wheel what offset do i need to run for the wheel to be flush without the need for spacers.
im trying to not run spacers if i don't have to.
Old Aug 26, 2010 | 03:40 PM
korito727's Avatar
Whips Come From Japan
run wider wheels
DIE WITH STYLE
£ THEORY87 ¥
Old Aug 26, 2010 | 03:48 PM
Garrett's Avatar
pfft.....
thought about that to
Old Aug 26, 2010 | 04:04 PM
seven's Avatar
Take the offset of your stock wheel (et35, et38, etc) then subtract the amount of the spacer normally used to get your desired look. For instance if your stock et is 35 and you would need to add 8mm spacers in the front to get flush you would be looking for a wheel with a 27mm offset. The rear is the same formula; et35 minus the 15mm spacer gets you a 20mm offset. I think that's the info you're looking for. Took about 2mins on google to figure it out.
___________________________
Blue Collar Motor Sports
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Aug 28, 2010 | 11:50 AM
Hellaslow's Avatar
...TR's resident Racist..
A clever person solves problems but a Wise person avoids them... A.Einstein
Old Aug 28, 2010 | 02:54 PM
Clifford's Avatar
weezin the juice
Originally Posted by korito727
run wider wheels
That's of no help at all...you could run 10" rims at a retarded offset and have it not be flush and rubbing the suspension.../pissy mood...
Old Aug 29, 2010 | 02:03 PM
Justin@UroTuning's Avatar
with a 7.5" wide wheel you can run a 15-20mm et. BUT you likely wont find any wheels with this ET unless they are custom made. Most wheels will be a 35et and you can run 15 or 20mm spacers for that flush look. it just so happens we have some on special right now! UroTuning.com - Parts for VW Audi Porsche BMW - This is the REAR btw, the fronts would need a 10mm or 12mm to get flush with a 35et
Old Aug 30, 2010 | 09:27 AM
D1ZzL3's Avatar
Im so HoodRich
^look at this guy such a salesman^ just get wider wheels man, oh you have a mk4 you say? well it just so happens that justin over at urotuning is a dealer for miro wheels, they have some ill designs that will surely get your car internet famous, or even better, infamous
slam.poke.stretch.broke.
Tampa knows not of stance
Old Aug 30, 2010 | 08:49 PM
Hellaslow's Avatar
^ funny stuffs
