need help asap!!!!!!!!!!!
well i was going to my car today but there was car pulling out next to mine and since i just needed to get something out,i unlocked it from the passangers side,or so i thought it ended up locking it so i just went around and when i went to unlock it BAM the alarm goes off it wont stop so i disconnected my batterey BUT now he passanger side wont UNLOCK it's like the key gets stuck and wants to break any ideas????? the car wont start and i cant open the passanger door,yes ive tried to unlock it mannually and with the lock button but nothing works!!! please help me out!!
Here is what I have had happen with two different MK3's.
First one: I went to turn the key to unlock it, and the lock cylinder jammed (on the driver's side). I went to the passenger side to unlock it and once I opened the door, the alarm would not stop going off. Finally, after opening both doors and the hatch, then closing them, and relocking the car with the passenger side lock, the alarm turned off. I then unlocked the car from the passenger side and everything was fine after that.
Second one: I had a car that had the lock cylinder slightly out of alignment or something. I had to slightly pull the key back towards me in order to operate the lock, otherwise it would not turn.
My advice, hook you battery back up, and play around with it, you'll get it eventually.
^ ill try it, but kind of hard to do with the alrm going off i live in an apt complex. i think what happned is the the passanger side is jamed but i do not want to break the key,any advice on what to use?
factory alarm? factory radio? if you still have it hook it back up. Call up Reeves or Kuhn with your vin number and some kind of proof it's your car. They'll give you the factory alarm code to disable it.
Der schnellste mann im langsamsten auto
