need some help
Old Mar 18, 2010 | 09:54 AM
kylealmostvw's Avatar
hellafail
Default need some help
does anyone have an obd2 2.0 manual tranny ecu i can borrow to see if my jetta's ecu is fried. the car itself wont crank through the ignition. thought it was an ignition switch and it was replaced but still no power. at the ignition wire at the starter. you can jump the ighnition and the car will start but it runs like shit. though i think it may have a fried ecu cause when you connect the battery the cluster shows the oil and coolent blinking and trunk and battery lights are on even with the key out of the ignition and ive tried about everything i can think of to get the car to start except try an ecu. i would take the one from my golf but its obd1. any help. shared_pm or text me if you have one. 7274094366
Originally Posted by G-Magoo
lower it till you take reflectors off the ground. then lower it more.
Old Mar 18, 2010 | 12:22 PM
seven's Avatar
Had a similar problem with the bug. Ended up being a bad contact in the relay panel under the dash. Look at the 2 relays with the number 5 on them. I simply swapped them and it worked fine. I couldn't tell you if I had any lights on the dash or not i no longer have a gauge cluster. If you need some help tracing down the problem, let me know I've got the bently for the bug (should be close to yours) and have gotten pretty good at reading the wiring diagrams. Your ecu is more than likely ok, unless you welded on the car with the battery hooked up. You could always bring your ecu to me and if it plugs into my car then we can see if it works.
___________________________
Blue Collar Motor Sports
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Mar 18, 2010 | 12:31 PM
hellafail
thanks man but i think your thinking its and mk4 2.0 its an aba but i can see how they would be similar. but i tried something similar to what you said and it didnt do anything. also i forgot to add nothing inside the car works either. power locks, trunk release, sunroof, etc..
Old Mar 18, 2010 | 01:32 PM
kawie636's Avatar
Hooligan
maybe your alarm is bad?
Originally Posted by _Will_
Mike was the obvious hooligan of the crowd, the sport bikes all looked like they were on warm up laps
I Bleed Green!!!!
GO VOLS!!!!!!!!!!
Old Mar 18, 2010 | 01:33 PM
hellafail
bypassed the alarm
Old Mar 18, 2010 | 04:04 PM
Signal7cbr!'s Avatar
hates change
sounds like its more than an ecu problem there bud.
Originally Posted by b16sleeper
don't worry...if i see a white guy with an afro...i'll yell crackhead and watch the cops tackle you before you touch me..
Old Mar 18, 2010 | 04:53 PM
hellafail
thats what im thinking but i would like to try another one before i but so im not spending the money for something i dont need
Old Mar 18, 2010 | 05:10 PM
seven's Avatar
I'm thinking MKIV, but my bug is a 98 so it's kind of a 1/2 breed. Might still be able to help.
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Mar 18, 2010 | 06:06 PM
korito727's Avatar
Whips Come From Japan
Ohh noo
DIE WITH STYLE
£ THEORY87 ¥
Old Mar 19, 2010 | 09:33 AM
elscruffalo's Avatar
picked last in gym class
damn if you dont want it ill buy it for 300 bucks =)
