need help once again.....
Old Mar 11, 2010 | 02:50 PM
Stiggy jr.'s Avatar
Default need help once again.....
Ok so I need to switch out the MAF housing and sensor from my 1.8T to a VR6 MAF housing and sensor. any info on how to do it or where to get these parts at a reasonable price will be greatly appreciated.
Old Mar 11, 2010 | 04:15 PM
seven's Avatar
It should be just plug and play. Is there a difference between the two? Just asking, alot of manuf. use the same parts and just tune the ecu to look for different values. For new i'd go to justin. For used maybe hit up the vortex or ebay.
___________________________
Blue Collar Motor Sports
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Mar 11, 2010 | 06:21 PM
Stiggy jr.'s Avatar
thats the thing, I dont know if they are different sizes. I have a custom intake that has the sensor atached to it and its 3 inches in diameter, but some people say that might not work...
Old Mar 11, 2010 | 09:28 PM
G-Magoo's Avatar
July - Ride of the Month
the VR housing is bigger, from what i understand the ECU wont be able to read the air flow correctly and possibly make the car run poor.
I love haters..
Originally Posted by VR6exxy
I love your brutal honesty. It makes my day
Build thread
Old Mar 12, 2010 | 03:40 AM
Jr_SS's Avatar
S one 4
Yes, you can't just throw on a bigger MAF and expect a stock ECU or any ECU to adjust for it without the correct values. I'm sure there is software out there that you can use to adjust for the MAF change though.
Why are you swapping MAF's? Have you maxed out the 1.8T on power potential? Or are you just wanting a larger dia intake pipe?
Old Mar 12, 2010 | 10:56 AM
Justin@UroTuning's Avatar
unless you are running specific tuned for the VR6 maf housing AND sensor this isnt something that should be done!
Old Mar 12, 2010 | 01:20 PM
Stiggy jr.'s Avatar
I'm doing either a REVO stage 3 tune or Unitronics big turbo file. they both require a VR6 MAF with stock sensor. thats why I was asking.
Old Mar 12, 2010 | 02:58 PM
seven's Avatar
If the tune is set up for it then there should be no prob. You can get an adapter from autozone for the maf. Look in the rice intake section, you can stretch it a little past what it says you can.
SCCA ITC New Beetle
sponsors:
urotuning.com
Old Mar 12, 2010 | 04:45 PM
Jr_SS's Avatar
S one 4
If you're getting it tuned for it then there's not reason it shouldn't work. Next time give more details in your questionare...
