Power Steering Problem
Old Mar 10, 2010 | 10:53 AM
DarkKnightSRT's Avatar
TOKEN
Default Power Steering Problem
Hey Guys, Im Having A Hard Time Trying To find Out Wat This Part Is Called. ive Been To Autozone, Napa, Advance And Nobody Can Give Me An Answer On Wat It's Called. I Called Audi And They Just Gave Me A Part Number And Wont Tell Me Wat It Is, So Any Body Who Is Familar With Audi's, Please Let Me Know Wat The Hell this Part Is Called. Thanks! The Part Is For A 2002 Audi TT
BOOST: mY aNtI dRuG
Old Mar 10, 2010 | 02:38 PM
DubDaze's Avatar
VeeDubin It
Im almost positive thats the "power steering cooler"
they run the tube like that in a attempt to cool the fluid.
this is what it looks like on my A4:
Most people convert to this style for better cooling:
Old Mar 10, 2010 | 02:57 PM
TOKEN
where can i get a power steering cooler for my audi tt from?
BOOST: mY aNtI dRuG
Old Mar 10, 2010 | 03:17 PM
DubDaze's Avatar
VeeDubin It
A audi dealer should have it if they knew what you wanted. Parts guys are retards sometimes.
Old Mar 10, 2010 | 03:20 PM
TOKEN
yea i was looking for a after market one
BOOST: mY aNtI dRuG
Old Mar 10, 2010 | 04:29 PM
DubDaze's Avatar
VeeDubin It
If anything use "Fuel injection" hose and used tubing cutters and splice in hose where your damaged line is now.
You can also use a fuel cooler as a power steering cooler also
Old Mar 11, 2010 | 03:54 AM
TOKEN
AhHa! I tried using fuel line hose and i put two clamps on each side of the hose and i put rtv around the ends to make sure it didnt leak and it was fine until i turned the wheel and it split right in half, so now i tried using high pressure pvc tubing from ace hardware and its soooooo much thicker and stronger than fuel line hose and its working but it popped off at the end, so now im using JB Weld to keep the bottom part from coming off and if that works then ill be happy, if it doesnt im gonna shoot myself cuz i tried everything possible lmao
BOOST: mY aNtI dRuG
Old Mar 11, 2010 | 04:29 AM
DubDaze's Avatar
VeeDubin It
Did you use regular fue line hose, or fuel injection hose?
there is a big difference in price and psi.
Most Fuel injection hose exceeds 900 psi.
regular fuel line hose is 40 - 50 psi.
it will also say on the side of the hose if its for fuel injection use.
Old Mar 11, 2010 | 04:57 AM
TOKEN
it was fuel line hose, im like 85% sure it was.
BOOST: mY aNtI dRuG
Old Mar 11, 2010 | 05:53 AM
DubDaze's Avatar
VeeDubin It
then get fuel injection hose next time?
