tail light help
alright, so randomly both my tail lights arn't working, brakes lights work reverse works and blinkers work....any idea?
03 Chevy Tracker-Sold
98 vw GTI Vr6-Sold
95 vw Cabby 2.0T-stolen
95 vw Jetta 2.hellaslow-sold
98 vw GTI Vr6-Sold
It's possible, but unlikely that both tail light bulbs would go out simultaneously. Check that the plugs aren't loose. If that doesn't work then I'd say to just go ahead and buy new bulbs. Even if it turns out to be a wiring problem, it's not that much of a loss, and either way, you're going to need to replace your bulbs eventually.
If your taillights were working just fine before, it should be as simple as changing a fuse. I don't see how the wires would cross or lose connection randomly.
Also, if the fuse is intact, try pulling it out and reconnecting it. It's possible that it got loose through vibration.
thankkkk you for posting this diagram,!!!! i didnt know what to search or where to look for this lol.
98 vw GTI Vr6-Sold
98 vw GTI Vr6-Sold
Hahaha. No problem, man.
I just did a google image search for "mk3 gti fuse"
VWvortex Forums: '94 SLC fusebox diagram
Turned out to come from a VWVortex discussion (figures). Some guy wanted the diagram for his 94 Corrado. They all use the same wiring system for OBDI, so it should apply.
lol right on, but since alot of stuff is attatched to fuse 10 that would mean that all of that would be not working as well right? cuz everything else on fuse 10 works, just not the tail lights.
98 vw GTI Vr6-Sold
98 vw GTI Vr6-Sold
got everything working!!!!! the vibration of the open headers knocked allll my fuses out! my a/c and windsheild wipers now work too haha. thanks again!
98 vw GTI Vr6-Sold
98 vw GTI Vr6-Sold
