mk3 vr problem
Old Feb 4, 2010 | 08:45 PM
jettahead99's Avatar
Default mk3 vr problem
Well i just bought a vr gti today, it had been sitting for 3 months without running, but i used started fluid and it worked,great deal didn't turn off only thing i am wondering is what is the problem it WILL NOT start without the started fluid. Any advice? i put STP fuel cleaner and filled the tank with premium. I am thinking it is either the battery,alternator,fuel filter, or the MAF any help is appreciated, will have pics later tomo got to get it buffed/waxed i drove it 60 miles home with no problems what so ever
Originally Posted by SayWhaa?
shut your mouth.
Originally Posted by rotarykidd
i wont 'till you fuck it.
Old Feb 4, 2010 | 08:52 PM
jgti1's Avatar
AKA: jgti
See if the fuel pump is flowing. If the gas tank had old gas in it, that could be a problem. Fuel goes bad after a couple of months, it will turn into a honey like sludge. I would start there. If you need to use starter fluid to start the car, it's sounds more like a fuel problem, than an electrical issue.
DA BUCKET
<a href=http://i84.photobucket.com/albums/k22/jgti/100_3052-2.jpg target=_blank rel=noopener noreferrer nofollow external target=http://i84.photobucket.com/albums/k2...100_3052-2.jpg" border="0" />
Old Feb 4, 2010 | 09:06 PM
^ thanks man ill check that out i thought of that to thats why i put the fuel cleaner+preium shell v power(like that shit works but yeah)
shut your mouth.
Old Feb 4, 2010 | 09:16 PM
jgti1's Avatar
AKA: jgti
I'd drop the fuel tank, and clean it out with POR-15 marine clean. I used this on a MK1 I rebuilt many years ago, and it worked well. You can also used pick-up about 3 gallons of acetone from Home Depot. The acetone will work the same way as the POR-15.
DA BUCKET
Old Feb 4, 2010 | 09:19 PM
jgti1's Avatar
AKA: jgti
Also a bad MAF won't keep the car from running.
Bad battery can take a jump, or slightly turnover.
A bad Alt. will drain a battery.
DA BUCKET
Old Feb 5, 2010 | 04:06 AM
^ you got a point thanks man im going to take it to a shop today
shut your mouth.
Old Feb 5, 2010 | 09:31 AM
Justin@UroTuning's Avatar
so onces its started does it run ok??
Old Feb 5, 2010 | 10:53 AM
yes it runs perfectly not 1 problem i drove it today to school and back just wont start up with out starter fluid, shops closed, got to wait until monday.....
shut your mouth.
Old Feb 6, 2010 | 02:59 AM
sirt8669's Avatar
私は昼食のためのあなたのお母さんを持っ ていた
Glad there is some insight as to why it was having a hard time starting. Take it to Les at Eurotech, he will get it fixed for sure.
"I love Asian chocha" crew member #001
"Anime Freak" Crew Member #001
Old Feb 6, 2010 | 02:08 PM
i changed the fuel filter today and some old gas came out, it looked worse then oil it started up right after hope thats it
shut your mouth.
