window problem!
Old Oct 11, 2009 | 09:30 PM
sb42991's Avatar
stay badgless
Default window problem!
alright, so my passenger window doesnt want to go up, but it loves going down (sounds kinky) anyway.
i was wondering if anyone could help me.
Old Oct 12, 2009 | 02:27 AM
kylealmostvw's Avatar
hellafail
crank or power windows?
Originally Posted by G-Magoo
lower it till you take reflectors off the ground. then lower it more.
Old Oct 12, 2009 | 05:12 AM
drftdfc3's Avatar
Maybe the switch is faulty?
Old Oct 12, 2009 | 05:54 AM
BisquitMan's Avatar
Salad Tosser
Probably the regulator.
Old Oct 23, 2009 | 12:23 PM
sb42991's Avatar
stay badgless
forgot about this thread lol. power.
and yeah im thinking its just the regulator.
it seems like the window is forcing itself down, its not falling the motor is pulling it down.
Old Oct 25, 2009 | 05:52 PM
mech7777's Avatar
Broken... I can fix it!
Default Switch problem.
Question, does both switches drivers and the one on affected door do the exact same thing. If so then the master switch may be your problem. If it was the regulator then the window would not move at all in normal situations. Or there would be some crunching or grinding noises coming from the window. The VW window regulators are a good design unlike the American vehicle manufactures designs of old. Any way feel free to ask questions. Jayfroelich@gmail.com
[HR][/HR]The funniest thing about this particular signature is that by the time you realize it doesn't say anything it's to late to stop reading it.
2014 Sc10n FRS 10-Series
#655 of 2500
Old Oct 25, 2009 | 10:14 PM
sb42991's Avatar
stay badgless
it happens regardless of which switch i use.
Old Oct 26, 2009 | 04:40 AM
mech7777's Avatar
Most likely it is the master control in the drivers door. I think you can grab one used for really cheap. I would say best thing to do first is find a working one and test yours by swapping it out with a known working one. I am sure someone at a meet or on here might have an extra one they would be willing to let you try out for a few minutes to see if it is the problem. The reason I say do this first, is one electronic switch in the driver's door normally are the cause of the a lot of problems. Since all the of the window controls route through it. Plus it is an easy test as opposed to the "regulator".
#655 of 2500
Old Oct 26, 2009 | 09:07 PM
sb42991's Avatar
stay badgless
true true, thanks man, im gunna wait till i get the clutch fixed first before i worry about anything else lol.
