03 GTI HELP!! Air conditioning
Old Jun 16, 2009 | 08:55 PM
seminoles131313's Avatar
Default 03 GTI HELP!! Air conditioning
Ok so im driving home 2 weeks ago and my air conditioning just stops blowing cold and just starts blowing room temperature.... my uncle has his own mechanic shop so i take my car there any time it needs anything so that i dont get charged crazy prices but when i took it to him he said the compressor was fine... he checked my ambient temp switch---pressure switches---fuses--- and he looked in my computer but could only come up with 2 codes that had been thrown... one was for my 02 censor cause i have exhaust on the car and the other was 01330 but he said only vw has the exact specifics and i have to end up taking it to them.... i need help cause i really dont want to go there.... any suggestions???
also when i click the AC switch on from the inside of my car it sends the signal to the control module cause the car idles different and also the computer my unlce has showed the signal getting there but we cant figure out why the compressor wont turn on after that.....
Old Jun 16, 2009 | 09:45 PM
mikiemike75's Avatar
mikiemike75
does the car have climate control... i had the same problem happen in a previous car... the climate control switch went out and when it did it was stuck at a high temperature sounds like my same issue... everything worked fine just blow room temp...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jun 17, 2009 | 06:36 AM
i just bought the car only like a couple months ago so im guessing it has climate control.... i think we checked that but we might not have... thanks for the idea....
Old Jun 17, 2009 | 07:51 AM
Madness's Avatar
AntiMatter
did you check to see if the condenser went out?
Old Jun 17, 2009 | 10:20 AM
GOTTI's Avatar
OEM Parts Specialist
fan control module good?
Old Jun 17, 2009 | 10:33 AM
ChrisMonsod's Avatar
Drives a cowboy corvette
un hook the battery for 10 mins and hook it back, its resets something... it work for me when i had a mk4 jetta that .. i read it somewhere and believe it or not it worked ..
Old Jun 17, 2009 | 05:52 PM
i did the battery thing... i heard that too about people just doing that and letting everything reset... i checked the condensor and it was fine.... im asking around and no one can find out what it is... im taking it to vw tomorrow so looks like im spending money
Old Jun 18, 2009 | 11:19 AM
hmmracing's Avatar
dabeetereater
is it manual ac or the automatic climate control?
do you know if it even has any free on left in it?
do the both fans come on if you turn the ac on?
and does the compressor kick on?
pm me i can help ya out man
EuroRat #2+#3
"YEA THOUGH I ROLL THROUGH THE VALLEY OF THE SHADOW OF RICE, I WILL FEAR NO TURBO FOR DISPLACEMENT AND TORQUE ART WITH ME... MY RODS AND MY PISTONS THEY COMFORT ME.."
bought not broken!!!
member #2
"having a big turbo is like having a big dick; it's not immediately obvious to everyone, but you have to just rest assured that when it comes time to put it to use, you won't need to explain a whole lot afterwards"
