UGH!!!
Well I finally got my car back from the dealer yesterday. When I went to test drive it (my dad picked it up for me) it had a check engine light on. They forgot to hook up a connector on the manifold but I was able to solve that and made the light go away. Im also missing the splash shield underneath so I have to go back for that. What really sucks is that the vibration is STILL THERE!
VW dealerships just plain suck! How can they make such good cars but have lousy dealers?
Dont get me started on how many times Reeves has fed up my car when it was being serviced. They broke my exhaust and told me Its not our fault its aftermarket.
2003 Volkswagen GTI 1.8T Silverstone Grey
Guest
Posts: n/a
Originally posted by "Someone"
Originally posted by AcmeVR6
Dude take me for a spin in your car. I may have a few good ideas as to what it could be. What possiblities have you eliminated and where does the vibration seem to be coming from?
Symptoms:
· Can really be felt starting around 40mph
· RPM independent drive train independent (ie. push in clutch put in neutral and its still there)
· Felt through the entire car (you can see the steering wheel shake).
· Last set of tires were worn to cause a pull to the right although no odd wear pattern was on the tire.
Things tried/replaced:
a. Several sets of rims and tires (Current tires are brand new)
b. Numerous alignments
c. Numerous re-balancing of tires & rims (even on-car balancing)
d. Rotation of tires
e. New drive axles
f. New front rotors and pads
g. New suspension (includes springs/struts/strut bearings/rear bushings)
h. New differential and carrier bearings (this was just done).
Its almost like its a wheel bearing tie rod end or ball joint but I dont feel any play anywhere or hear any noise.
BTW hows the malibu?
