Helppppppppppp!
Old Oct 14, 2007 | 03:16 PM
RkSport's Avatar
Default Helppppppppppp!
I missed a gear shifting from 3rd to 4th and hit second, immediately after my engine started to run funny, I changed the spark plugs but it still has a lack of power in all gears can any one help me out with what the problem may be?
Old Oct 14, 2007 | 03:18 PM
Scott90's Avatar
Ecotec y0!
dont quote me on this....
but could missing a gear mess up your torque converter at all? just a guess?
"Decide what you want, decide what you are willing to exchange for it. Establish your priorities and get to work."
Old Oct 14, 2007 | 04:08 PM
BisquitMan's Avatar
Salad Tosser
I will quote you on that...
...Because it is the most illogical thing I have heard in a while. It he was shifting and missed a gear, he has a manual tranny and would not have a torque converter.
To the OP, worst case scenario is valve damage due to the over revving. Valve damage would lead to lost compression and loss of power.
Old Oct 14, 2007 | 04:21 PM
SmokinS13SR20's Avatar
That ginger...
There is also the possiblity of the ecu going into limp mode.
Try pulling the main engine relay and letting her sit for a few minutes.
G/l man.
Old Oct 14, 2007 | 04:28 PM
DA92driver's Avatar
time for a new head
Old Oct 14, 2007 | 04:43 PM
DubDaze's Avatar
VeeDubin It
What rpm did you rev to, probably floated the valves
Old Oct 14, 2007 | 05:32 PM
RkSport's Avatar
i was switching to 3rd to 4th and hit 2nd i dont remember what rpms it was high... i heard it can be the coil packs? it drives with lil power but i can still drive it and its misfiring on a 2000 audi.. i have searched people have said they had the same problems and it was the coil pack can this be it?
Old Oct 14, 2007 | 06:53 PM
3drwhore's Avatar
Pending....
I dont see how you are concluding over-revving your motor is a coil pack or spark plug issue.
go to sears and buy a compression gauge and check that first.
Old Oct 14, 2007 | 07:48 PM
DubDaze's Avatar
VeeDubin It
Maybe there thinking they popped out? but if you changed your plugs already then you know its not that.
Old Oct 15, 2007 | 10:07 AM
Garrett's Avatar
pfft.....
is your check engine light on now?
if it is just have someone with an obd2 scanner scan your car it. I think autozone will do this for free.
or better yet find someone with a vag-com
