1.8T Bailey valve
I dont even know if there are any other 1.8T owners on this list beside Jim and I but...
I just installed me Bailey valve from AWE. The main thing I noticed was that the power does not drop off nearly as bad after the peak at 3500 rpm. It seems to hold the boost a little better. Has anyone else used a different valve? What do you use Jim?
John - 1552 Design
Cool White Jetta 1.8T
20psi (178.1hp 239.8tq)
projektzwo body kit
H&R coilovers
John - 1552 Design
projektzwo body kit
H&R coilovers
Bailey valve? Umm is that a blow-off valve or wastegate? Ive never heard that term used before.
Joe
Joe
Joe - Bailey Motorsports is a British company that makes a replacement for the factory diverter valve (blow-off valve).
Jim - Heres my dyno curve:
Have you dynoed your car? If so how does the curve compare? My stock DV made the infamous honking noise as soon as I bought the car. I replaced that with the Porsche valve which solved the honking problem.
John - 1552 Design
projektzwo body kit
H&R coilovers
John - 1552 Design
projektzwo body kit
H&R coilovers
Thanks for the clarification.
Joe
Joe
As far as I know its just the normal APR chip. I just got my new VDO Vision boost gauge so this weekend Ill be able to tell you exactly how much boost my car is running. My old VDO Cockpit boost gauge would bounce between 15 and 25PSI.
John - 1552 Design
projektzwo body kit
H&R coilovers
John - 1552 Design
projektzwo body kit
H&R coilovers
