rubbing
Old Aug 26, 2007 | 05:25 PM
RoadRacer's Avatar
Turn 7 at Sebring
Default rubbing
It looks like my sway bar is rubbing on my axle.
Will aftermarket end links fix this?
The car is a mk4 will coilovers.
Thanks
Old Aug 26, 2007 | 07:03 PM
DubDaze's Avatar
VeeDubin It
Thanks
Get adjustable endlinks and raise them up, or just buy a new aftermarket swaybar.
BFI Adj Heim Joint Swaybar Endlinks
Old Aug 26, 2007 | 07:17 PM
RoadRacer's Avatar
Turn 7 at Sebring
thanks
Old Aug 26, 2007 | 07:51 PM
iglOo's Avatar
Euro Rat !!
rubbins dubin bro lol
SILLY RICERS, USELESS WINGS ARE FOR PENGUINS!!
Bought Not Broken!!!
Member#1
EuroRat
http://www.facebook.com/home.php?
Old Aug 26, 2007 | 08:24 PM
RoadRacer's Avatar
Turn 7 at Sebring
lol I was waiting for that.
Patrick -
Old Aug 26, 2007 | 08:55 PM
DubDaze's Avatar
VeeDubin It
You rub the swaybar, i rub the frame rail
Old Aug 27, 2007 | 06:10 AM
Green_Lantern's Avatar
Green Lantern Corps
sway bars are over rated! Just take it out lol....
If you're not cracking oil pans your not low
Old Aug 27, 2007 | 08:53 AM
RoadRacer's Avatar
Turn 7 at Sebring
hahaha, you say that but I removed the front sway on my scirocco and just ran a big rear bar. It helped rotate the car on the track.
Patrick -
Old Aug 27, 2007 | 11:12 AM
Green Lantern Corps
Dont drive the GLX fast and make turns fast and you should be straight. Then you can slam it more
I'm just messing with you man. Adjustable endlinks should do the trick...
