mk3 window motors
Old Feb 2, 2007 | 04:57 PM
Justan8valve's Avatar
full color high res
Default mk3 window motors
Alright after getting the driver's side window regulator and motor out today, i found out that the regulator was fine. The gear inside the motor warped somehow and the smaller part that fits into the regulator broke. So i am wondering if the window motors are universal, as in i can take one from any other door and it will work on the driver's door. I'm pretty sure they are, i just wanted to double check before buying a motor from somewhere.
Also, if anyone has a motor or knows of a place in the tampa area i can pick one up from, please post up.
Old Feb 3, 2007 | 02:43 PM
BisquitMan's Avatar
Salad Tosser
I think they are different for left and right side doors.
Old Feb 5, 2007 | 12:39 AM
krsmanovic's Avatar
i believe mk3 motor on driver side is the actual power window module,look into it before u do it i cant remember it might be mk4 tho
Old Feb 6, 2007 | 09:56 PM
full color high res
must be a mk4 thing because the driver's front door motor isn't in the car at the moment and all the other windows work.
i really only need that plastic gear part, so a motor from any door will work anyway
Old Feb 7, 2007 | 02:49 AM
gbabystunt101's Avatar
check this place out. Porsche Parts and Accessories, Audi Parts and Accessories, VW Parts and Accessories from PAP-Parts got alot of good deals
coolwater vw club!
THE RATTLE CAN MAFIA
