B5 help?
Old Aug 19, 2006 | 05:31 AM
Paul's Avatar
Motha Fawking Baby Maker
Default B5 help?
well we have had a flashing CK eng light from day one...and I dont mean flashing like every 2 sec....like random it comes on and go's off...well lastnight changing the oil in the car and start it up and hear a new noise...from under the hood....almost like some thing is ticking in the valve trail or timming belt is flaping....???I am ready to fix all and tri and sell the car...any one local know a shop that is good to there word and not tring to get over on people for VW's?
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Aug 19, 2006 | 06:10 AM
BisquitMan's Avatar
Salad Tosser
Could be misfiring. Is it a 1.8t or 30v V6?
Old Aug 20, 2006 | 05:31 PM
Paul's Avatar
its a 1.8t...it does not sound like a miss fire...more like a tick from the valve train or a cut/tear in the timing belt...not even sure it has a belt...
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Aug 20, 2006 | 10:28 PM
Justan8valve's Avatar
full color high res
loose timing chain? i know those go in the vr6's and make a slight clicking noise, maybe need a new tensioner. just a guess though.
Old Aug 21, 2006 | 03:59 AM
BisquitMan's Avatar
Salad Tosser
Yeah, it has a timing belt. I would find someone with a VAG and see what codes it has. That should be a start as to what the problem is. Did you visually inspect the belt to see what condition it is in? How many miles on the car? If the belt is going bad, you will ruin the motor if it breaks.
Old Aug 21, 2006 | 02:02 PM
Paul's Avatar
car has 70k on it..I dont know any one local with a VAG....
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Aug 21, 2006 | 02:56 PM
BisquitMan's Avatar
Salad Tosser
Recommended timing belt service is 60K, I would look at the belt and consider changing it if it looks like it hasn't been changed.
Old Aug 21, 2006 | 05:05 PM
Kyle K's Avatar
vw/audi
When the belt snaps, you'll know. There arent any real signs of is starting to go. It just goes. So my guess is its something else. How's that for help?
cars and concepts can check you out. 348 6183
