Inside view of a VR6 head
Turn 7 at Sebring
on
This is the long intake port. Bildon started a real good thread in the vr6 engine forum. They are trying to get 250 whp via NA and 2.9 liters VWvortex Forums: VR6 12v engineering project >> 275hp
Patrick -
Patrick -
Yeah the keep the stock bottom end, but Anthony had an ITB set-up and put about 220 to the wheels. To squeeze another 30 hp out with only a slight increase in displacement would be quite an accomplishment.
i got 209 whp all motor on race gas with a mk4 headgasket, 276's, and worked motor. 250-275 seems a little high without a displacement change.
Mk2 vr6t chirpin' sixth...
Turn 7 at Sebring
on
Yea, Bill has said many times that 250 will be a big hill to climb, but he still wants to try get there. I do agree it will be hard considering they are use a 2.9 block.
Caan when you say worked motor are you talking about increased displacement and head porting? Where did the tq start drop off with that motor?
Patrick -
Patrick -
I try not to stick my nose in the VR6 business(my VR-knowledge is limited), but the ABF(VW Motorsport ABF, that is) made 260hp at the crank. I understand that cost is always the problem, but with the aid of two extra cylinders why is that so hard?
Der schnellste mann im langsamsten auto
4 valves per cylinder versus 2 valves per cylinder. I am sure the VW motorsport ABF was able to rev a lot higher than any AAA would rev also.
yes, a worked motor. 2.9 euro bottom end with forged internals and a DRS 42/36 BVH. 209 on race and 197 on 93oct.
The torque ran strong past 5000 right until 5600 and fell on its face.
Turn 7 at Sebring
on
thanks, that is a common theme, most if not all 12v VR6's fall flat at or around 5600 rpm... even with cams and head work.
Patrick -
Patrick -
