Ok so i scanned my car..
And this is what came up:
P0420
Catalyst Efficienct
Below Threshhold
(Bank 1)
P1142
Manfacurer Contrl.
Fuel Air Metering
P1545
Manf Cntrl Veh.Spd
Idle Speed Control
Auxiliary Inputs
Any ideas? MAF and IACV went bad?
I have an 00 GTi VR6 with a Magnaflow catback.. thats it.
P0420
Catalyst Efficienct
Below Threshhold
(Bank 1)
P1142
Manfacurer Contrl.
Fuel Air Metering
P1545
Manf Cntrl Veh.Spd
Idle Speed Control
Auxiliary Inputs
FLeuro
TheCommision
FLeuro
TheCommision
i think my car was throwin that same first code and it ended up being the cat. and thats a free under warrant up until 80k/8 yr. so if your under that get it checked out at the dealer.
XBOX LIVE username = nehah
vwvortex name = kylecrish
_/_/_/__/___/____/_____/______/_______/________////VW
The MAF seems to be a common problem, it's always good to have a spare, TB are also known to fail, I would clean the MAF first, than the TB and see if the problem goes away before replacing parts.
FLeuro
TheCommision
FLeuro
TheCommision
If you "clean" the MAF it will be ruined. You can't clean MAF's after the A3 chassis went away. A4 and newer elements are made w/ different materials and will fall apart if cleaned w/ chemicals. I think VW did this to sell more parts.
VW Certified Technician 2003,2004,2005,2006
'06 Passat Certified Specialist
New Beetle Conv. Certified Specialist
Phaeton Specialist
Touareg Specialist
'06 Eos Certified Specialist
Phaeton Specialist
Touareg Specialist
Guest
Posts: n/a
If you observe value block 01-08-032 in 01-Engine w/ someones VAG-COM you can look at fuel trim and I can tell you if your MAF is the problem. Also 001, 010 and 33-OBD, Mode 2, All PID's.
Phaeton Specialist
Touareg Specialist
Phaeton Specialist
Touareg Specialist
I would not start throwing parts at your car as these parts are WAY TOO EXPENSIVE to guess with.
Phaeton Specialist
Touareg Specialist
Phaeton Specialist
Touareg Specialist
