91 Golf Wolfsburg Edition question
Old Jun 21, 2006 | 05:24 AM
Ray's Avatar
Ray
Befürchten Sie Meinen Zor
Question 91 Golf Wolfsburg Edition question
so basically my situation is this, i recently bought a 1991 VW Golf, nothing wrong with it at all, excellent condition, considering it's age....but it's automatic, is there anywhere i can have the auto/5spd conversion done cheap and quick, btw, it's the 1.8L 8v....thanks!
-Ray
Vincent Mancini : Don Lucchesi, you are a man of finance and politics. These things I don't understand.
Don Lucchesi : You understand guns?
Vincent Mancini: Yes.
Don Lucchesi: Finance is a gun. Politics is knowing when to pull the trigger.
Old Jun 21, 2006 | 07:51 AM
mrnicejetta's Avatar
farfromügen
If memory serves you would also have to change out the digifant ecu to one designed for the 5spd. Sorry I can't think of any places off the top of my head.
Der schnellste mann im langsamsten auto
Old Jun 21, 2006 | 04:08 PM
Ray's Avatar
Ray
that's alright, thanks for the input....i just need as much info on it as possible, since i'm new to the VeeDub scene...i want to learn as much as i can in a short amount of time so i can start working on it....it was a good deal on it, but automatic...i can deal with it for a while, but eventually, want to have a turbo 16v 5spd, but that's for later...lol
Old Jun 21, 2006 | 04:23 PM
farfromügen
The best thing to do would be to have a lot of time, a decent amount of cash and go to a junky.
You'll be looking for a 90-92 Golf or Jetta 8v. As far as I know those are the only years that have the digifant management.
Just take everything as it should make things easier down the road: ECU, harness, tranny, pedal cluster, shift linkage, clutch cable, speedometer cable, I believe even the axles are different(but don't hold me to it). You'd be better off buying a new flywheel and clutch. Also before you put the tranny on rip it apart and replace the rivets that hold the diff together with bolts. From what I understand the most difficult part of the process is the pedal cluster installation.
This is an over-simplified list, but it should set you on the right path. Good Luck, and I'll try to help with any info I have.
Old Jun 22, 2006 | 07:51 AM
Ray's Avatar
Ray
sweet, thanks...good info
Old Jun 22, 2006 | 07:53 AM
farfromügen
No problem.
