supercharger questions????
Old Apr 10, 2006 | 02:14 PM
WhiteRice813rd's Avatar
Default supercharger questions????
i heard from different forums that if you turbo a car that if you have an aftermarket flywheel then you would actually lose hp and torque.. does it work the same if you supercharge your car???? thnx for info
Old Apr 10, 2006 | 02:21 PM
BisquitMan's Avatar
Salad Tosser
I think it would depend on the weight of the flywheel, if you have a real light flywheel, it will be a pain to move the car from a start, it should rev easier though. I am not a fan of lightweight flywheels. I would stick with stock or maybe a few pounds lighter.
Old Apr 10, 2006 | 02:54 PM
BoogieDown's Avatar
Area Man
I had a 7lb flywheel on my civic but it was NA. It was very easy to drive, took a day to get use to it but after that it was great.
Old Apr 10, 2006 | 02:58 PM
BisquitMan's Avatar
Salad Tosser
A civic is also a lot lighter than a VW so it takes less to get it moving.
